Speed of automatic watch
The escapement is designed to run at a given speed   and everything is tuned to produce that speed. Trying to drive it beyond its mechanical limits will lead to breakage of the escapement parts lilkey the pallet and rollerjewels as they are rhe most fragile part of the escapement.
Hi WW. Nice to have you back. Would the watch run faster if the bph was higher ?
2 hours ago, Snigdha said:
Can the speed of automatic watch be increased by 2.5times
Hi snigdha. What is your reasoning for wanting to do this ?
1 hour ago, Nibbler said:
just modify the dial to go from 0 - 30 instead of 0 -
20 minutes ago, RichardHarris123 said:
Unless anyone correct me, it must run faster.
Is it April the 1st today ?
Im starting to think a rather suspicious question. Snigdha please tell us more about yourself please 🤔
Edited by Neverenoughwatches
I have a suspicious mind and want to know more about the question
The basics are the design of the movement. All the gearing is calculated to give a set speed at the point of delivery (ie) the escapement and the balance. Lets say we double the strength of the mainsoring for example , all that would happen is that we would end up with  pile of scrap because the geairing and pivots cant stand the torque and it would only take one to break and the domino effect would ruin a good movement. Why. the gear train and pivots are again calculated to carry a given force. pushed too far = disaster.  Now letts imagine we hve a beefed up gear train, the weak point is then the escapement and either the pallet of balance packs in , again disasler. But if you redesign the gear train , alter the circumference and tooth count of the wheels tat would alter the speed but there must be a finite limit you can reach before the balance and pallet break down. so in order to double the speed you would need to redesign the watch from the bottom up . You need to source a movemnt with the required speed you want, that way you  know its designed to do the job and is comfortable running at the given speed.
The speed of a specific movement is integral to the design.
You can't take an 18,000 vph watch and cause it to run at 45,000 vph.
Tag apparently has one that runs at 1000Hz but at what point do you resort to atomic clocks?
You might read this:
https://www.montredo.com/the-fastest-watches-in-the-world-movements-with-oscillating-frequencies-far-beyond-4-hz/
Hi. We are diamond jewellery and watch company based in delhi,India. We are trying a new product thats why curious.
Hi. we are a diamond Jewellery and watches company based in Delhi, India. We are trying a new product thats why curious.
Okay 👍
Can you give anymore details or is it top secret  ?
5 minutes ago, RichardHarris123 said:
Attach it to a rocket, they reach speeds of at least 7 miles per second.
Rich what have you been reading ? Rockets and worm holes, are you studying space exploration and quantum physics mate 🥱
I have to say I'm still kind of suspicious 🤔
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
