3D printing mainspring roundel?
In an attempt to not break the bank I ordered only a subset of the right handed Bergeon mainspring winders (size 4 through 7). For those mainsprings that are left handed, my thought was to just first transfer the mainspring to a roundel and then flip it over and be good to go. I have a friend with a 3D printer who will print these for me and wanted to see if anyone here happens to have had the same idea and might have the files to share? If not, I will see if I can't learn how to use the software to make the files.
For the inner diameter size of the roundel, would you just make it, say, .2mm larger than the outer diameter of the winder barrel?
I'm not sure I understand the exact part you are referring to. However, building/using it as a custom 3D printed part might be impossible as the inner loop of the mainspring is quite small, thus the hook required for it will be very tiny. It is quite difficult to 3D print a plastic piece that tiny and still be able to handle the winding stress. Maybe this will change in the future. For files, you may take a look my 3D printed mainspring winder project: https://github.com/vishnu350/rs-mainspring-winder
A general guideline for part clearance would be 0.125mm (tight fit), 0.25mm (fit) and 0.5mm (loose fit). You will have to experiment with printouts to get a good idea of what works. I would recommend FreeCAD for designing custom parts.
I designed this as a first crack at it:
I wasn't clear in my first post. It's not for the winder, it's just the roundel so that I can take a left handed mainspring and wind it in a right handed winder, then insert it into this roundel, flip the roundel over and insert the mainspring into the barrel.
This is a for a #6 Bergeon winder with a 9.8mm barrel. I put in .2mm clearance, so a 10mm inner diameter and 1.2mm tall. My Bergeon winders are on backorder so will have to wait about  a month before I can try it out.
Edited by GuyMontag
Oh! I see now.  I thought you were talking about the winding arbor.  Yes, these are easy to make.  Take a look at my post this morning about the Mido crystal wrench.
21 minutes ago, Neverenoughwatches said:
Hi lws. I'm curious about the hook for it, what material did you use ?
Somewhere on this forum, I posted a picture of what I did...I think...but cannot find it yet.
I used what is called 01 steel I think.  It may also be referred to as "silver steel."  I learned about it from @nickelsilverabout a year ago.  It is soft enough to turn easily but is still plenty strong.  After turning the arbor portion, I drilled an orthogonal hole and drove in a piece of pivot steel that I had turned with a nib on it.  I felt like pivot steel was necessary because it deals with the stress.
Thanks for that, I was about to say whatabout steel filament  for the 3D printing, although I would think still not strong enough. I mostly wind by hand with a simple little whirlygig. I've just acquired a lathe and thought I would have a try at making something like you described. Was the hook difficult easy to do  and is it just a friction fit ?
It took me all day long, but as I recall, I had one misfire making me start all over.  It was a friction fit, but I may have put Loctite on it when pressing in...it was a couple of months ago...so some of those brain cells have already expired.
Was it hard?  I thought it was pretty easy until I got to drilling the holes.  The other thing I cannot remember is which starting material I had.  I may have had to do a lot of turning to get it down to the right diameter before starting the shaping.  It was fun though.
Pondering this further, 3D printing the arbor might work.  PLA is strong enough.  It would not be very pretty...at these dimensions, 3D results are are a bit rough.
Are you pleased with how the winder works ?
2 minutes ago, LittleWatchShop said:
The nibs are slightly too long.  I am gonna file them down a little whenever I am inspired to do so.  I have used it and it works, for sure.
Thanks. The hooks on the ones I've retired are pinched out from the arbor, so not particularly tough  I might make it my first lathe project. Springwinders are a thorn in my side. I've been scammed twice buying secondhand, which is why I've resorted to handwinding.
28 minutes ago, LittleWatchShop said:
With a lathe, you can fix the ones you got second hand.  Generally the only issue is the nib has worn.
Some it's the nibs and some its wear between the pusher and the inner wall of the winder. When pushing the spring out it becomes hopelessly trapped in the space between them.
    • Hello forum, I have just joined the forum and I believe it is the done thing to introduce myself.  I am based in Surrey UK and am essentially a complete novice at watch repair.  Fairly life long interest in watches, starting from not being allowed one as a child as I kept taking them apart… After watching a you tube video of a watch service, I thought to myself “I could do that…”. Well I got myself a Seiko 7002 dive watch that was a non runner. Striped cleaned and reassembled. With much blaming of tools, dropped parts and feeling out of my depth I got it working again. I built my own pressure tester and it leaked like a sieve! fixed now though.    I’ve since done a few 7002’s and an NH35A with mostly success. But now I’m left with quite a few working movements and no budget for cases. Overall my lack of a timegrapher has really hampered things and efforts using phone apps have been disappointing.    I next moved to an ETA 2472, all went well until I snapped the stem after failure to find a suitable case for it. Alas replacements seem almost the price I paid for the movement! Hopefully I’ll stumble on a suitable one one day.   Currently working on a Smiths 512 pin pallet movement. All went well until the shock protection. My goodness they are tricky compared to all the others and now I’m down one shock spring. This was my first movement I’d done with no video or walkthrough or even manual for backup. So I was pretty pleased with my self, briefly.  Well, that’s me and my watch repair journey.    Rob
    • Something odd is going on with email notifications. As I posted above with the screenshot, when I checked my notification settings I saw that somehow the option to send an email notification in addition to the browser notification was not selected, even though previously that had been working for me. So I selected the email option, in addition to the two top options of automatically following new content I post or reply to. I did not get an email notification for your post (I did get the browser notification), which I should have (it does show me as subscribed to this thread) and when I went to look again at my notification setting, the board software has again unchecked the email notification option (in addition to the two top automatically follow options). The below left is a screenshot of how it was setup after my last post and the right is how it was just now when I rechecked. For some reason the board is resetting this preference on its own.
    • I feel like I've achieved the next level up 😅 . First watch with homemade part installed ( setting lever ). FHF 73, not bad to work on, simple and sturdy, and part working perfectly.  An Avia and in time for this year's Olympics.  It has a teenage dial ( bit spotty ) 😅
    • We need to know the caliber.
    • I am.  On my phone just using the bell symbol, I don't bother with email notifications.  Actually I  stopped receiving email notifications a long time ago, I  don't remember cancelling them.
