Pivot not locating
40 minutes ago, RichardHarris123 said:
I'm having trouble locating the pivots of the wheels into the jewels. I have cleaned the plate and the wheels, are the jewels blocked?
Surely they are not. It's normal for beginners to have trouble,  even major one, bringing all pivots into the bridge. This is often asked, however repeating the answer one more time, there is no magic to it. First and most important is that you have the work very high as in shoulder or neck high, and your elbows resting on the bench. You need to see what you're doing, get an appropriate loupe. You can also try with one wheel at the time, then add one after another, and learn how to make tiny adjustments to the top of the arbor or pinion with the tip of the tweezers or a toothpick, from a side.
Hi.
I am also a beginner but one tip I picked up which often helps is once the bridge has been placed on top of the wheels with all its screw holes lined up, is to with the blunt end of tweezer tap the movement holder a few times rotating is as you go, doing this I often find most if not all the pivots have miraculously found their way into the jewel hole without any extra fiddling.
    • I thought this may be "right" forum to post this. After 7 months out in Switzerland I got my Navitimer back from Breitling. I had sent it off since its 20 years old to have a complete overhaul done... Nothing major wrong, but I did notice this seconds sundial skipping thingy.... $1300 later and 7 months later, I notice the 'skips' are still here unless the chronometer is engaged. I would think this is likely the hand binding up and maybe clearance with the dial, but at any rate Im interested as to whether this is something I should be returning the watch to Breitling for and insisting on being fixed. See below - 1 minute or so of regular running and then 1 minute with the chronograph engaged.
    • Hello everyone, I recently received a request for advice on purchasing a vintage watch, a Waltham A-11 ORD. DEPT. I asked if they were aware that these types of watches have radioactive hands and dials... but they had no idea what I was talking about. So, I thought of creating a video that could help recognize them, starting from the distinctive details to using a Geiger counter. I hope you like it and find it useful for those venturing into the world of vintage watches. Bye.
    • I’ve tried everything using both my blue and donut demag units.  I’ve even tried beating them with a steel hammer 🙂   im now trying heating them over gas flame — if that doesn’t work …..
    • The 110v supply could be problem with the blue one. Have you tried moving the piece to demag through different orientations manually as its drawn away ? As Nev quoted the magnetic fields of the demag have to overcome those of the steel.
    • Thank you Marc! I re ran the TG. First I went ahead and checked the balance jewel on the regulator and it was bone dry. I cleaned and oiled it, not without some drama including pinging the capstone and searching my bench with a black light for 30 minutes and finally shone it on my face and looked in the mirror only to find it on my left cheek in my 2 day growth! Back in and on the Grapher we are at 275. However significant drop in DD (234) and CR (190 edited) positions tells me it's time for a complete cleaning and oiling.
