Pocket watch case need help
Hi,
I'm trying to case up an Elgin 16s 313 that I cleaned/repaired recently. While the case is functional, the sleeve needs to be replaced or adjusted to keep the watch from always being in setting mode. However I'm having trouble getting the cap (or whatever it is called) off in order to unscrew the sleeve. I've included a picture and was wondering if there is some special tool or technique for this. I'd hate to brute force it and ruin the thing since it appears to be pretty soft brass and I have no idea where I might find a replacement.
Any help is greatly appreciated.
Edited by Levine98
clearity
That's the case tube and it's soldered to the case. No need to remove it. Remove the stem by gripping with smooth pliers and pull it through the inside of the case. If you have a proper sleeve wrench it should be no issue then to remove the sleeve. In many cases the sleeve can be accessed with the stem in place, so if your wrench isn't working removing the stem is the only thing I can think of that would help.
Thanks. Was able to remove the degraded leather washer and adjust the sleeve in place, as suggested. reassembled w/o leather washer (don't have anything to replace it with) but seems to be working fine now.
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
