Similar Content
You might like to see the contraption that I made for indexing on my Chinese lathe.  This is a 4 inch rotary table with dividing plates that I attached to my lathe mandrel using a drawbar. It is completely manually operated. No electronics or computer needed. I have used it to make a 60 tooth clock wheel. I use a Sherline headstock on a vertical slide to drive the gear cutter. The wheel blank is mounted on an aluminium "superglue arbor." This is the modern equivalent of a shellac chuck, and allows the wheel to be centre bored, trued and the teeth cut in a single setup, ensuring that concentricity is maintained.  The finished wheel after crossing. I have not tried to make small watch parts on this lathe. The runout on the mandrel bearings may be too high for that. I won't know unless I try.  Â
By coreymsnow · Posted
Y'all are very helpful, I can't thank you enough for the insights. Â -
By FabioBastardo · Posted
Will do. Funny it doesn’t have a makers name. -
