14 hours ago, VWatchie said:
I wouldn't be surprised if buying cheap watches sold for repair or parts and then repair them yourself is way more expensive than buying a Rolex watch. I actively avoid thinking about how much money I've spent on tools, parts, and consumables 😖
So far I have found it almost impossible to find an honest spares and repair watch or almost any watch on eBay, all the ones I have bought all seem to have some hidden history.
I suspect most people buy the Mumbai specials then sell them as spares and repairs when they eventually break. Might start restricting my purchases to flea markets band car boot sales to see if the standard improves.
When buying a "parts only", non-working watch from eBay, don't expect very much. Many of them were donor watches with all their good parts scavenged. And be extra careful when the buyer doesn't accept returns.
With watches advertised as "working", the prices won't be cheap. I especially like those from Japan, Korea and Hong Kong. I have a few of these that work well straight out of the box.
Mumbai specials are a whole different kettle of fish. The top grade ones are working watches that have not been properly serviced. The middle grade are defective watches that have been "serviced" by their in-house master watchmakers. Then there is their bottom of the barrel. I would not touch these with a 10 foot pole.
I buy Mumbai specials regularly. My mentor made me practise on them to test my level of skill. I would not advise beginners to buy these because if you do not know what is right, you won't know what is wrong.
I have bought some that, when opened, appeared not to have ever been serviced before.  I refer to them as virgins.  These are not high-end watches.  Things like Caravelles, Walthams, and stuff like that.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the esscape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
