Advice request- removal of bezel and tachymeter ring Seiko 7T94 0BS0
Well done Sam, you've successfully completed a tricky piece of work there 👍 -
Is there a lip above that ring coming towards the back of the case ? -
Hiya watch people, any more ideas on what to do here yet ? How about just adding ourselves to waggy's list for now. You dont have to add your full name and an email that can be trashed takes minutes to set up. -
By Michael1962 · Posted
Certainly looks like a ring that needs unscrewing in that photo. It definitely looks like a thread above the castellated ring as well. Separate to the caseback ring thread. It even looks to be a smaller diameter. I would expect that. Once undone out of its thread, it should fall out of the case. Would it be possible to make a tool shaped like a letter H with one side of the H engaging the castellations in the ring and the other side of the H for you to be able to unscrew it using your hand? Making a tool with 6 'legs' to pick up all of the castellations would be a labour of love.
