What would be the correct fix?
I’ve been tinkering with watches for a long time and I haven’t seen a failure like this yet. I could put thread lock on it or deform the head and put it back in and hope for the best but what would be the correct fix for this bracelet pin? I appreciate the help. ⌚
Edited by TheOtherGuy
Additional photo.
Hi  Loking at the bracelet end It looks like a Rolex type. The fact that the end has come off  is probably due to loose pin (Knurled) or a worn hole. The correct waty would be to replace both the link and the pin which if the bracelet is a rolex then expensive. The use of thread lock would work ok.  I did the same on a seiko a few years back and its still intact and working ok.
Thanks, not a Rolex but a modded generic case & bracelet.
I suppose one way would be to try and shrink the center hole a little to make it a tighter fit on the knurled pin. Working around the outside of the hole with a center punch should shrink it enough, or the use of a domed punch in a staking set if you have one would be a neater option. Or as you suggested a thread lock just make sure it's a strong one.
As its a generic bracelet and punching the rim could cause deformity and only closes the top edge, probably the best idea is a combinatiobn of both. Using a domed or hole closing punch and thread lock. hole closing punches can be purchased at Cousins uk    at a cost of £27.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
