Advice on replacing a steel chime rod.
kouroshk
Hi
This is my first attempt at repair so am looking for any advice. The first step in restoring the clock I have is replacing the chime rod. I have found similar rods online but the specs dont match. The thread diameter is 6mm and the length is 18" including the screw mount. I have found matching rods but the main difference is they all have a 6.5mm thread. Am I missing something or am I stuck with something very specific. I would really appreciate a nudge in the right direction please.
Thanks in advance.
Could you show me the movement. The problem you will most likely have is getting the tone correct. I have found in the past it is best to replace the whole lot, that is why I'd like to see the movement because if you are thinking of getting a second had set I can look on ebay and the net to help you.
That is a Westminster chime with strike normal duration 8 days. I would say its German I was hoping to see some sort of I D on the back plate but nothing. What is on the dial if anything.
I have just found this set they are new.
http://www.m-p.co.uk/muk/parts/chap03/cast-iron-gongs,-8-vertical-0904845015.htm
You will need to log into this site to get all the details of sizes I suggest you phone them and see what they have. I would say this is the best place.
https://www.cousinsuk.com/category/gongs-hammerback
    • At some stage you will have to jump in and have a go.
    • Ah so its you thats buying up all the DD calibres 🤨.
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
