I thought I'd share this as it's now the oldest watch I own which I've managed to get to imperfect perfection. It came to me in a job lot and consider myself lucky to have it come into my possession. With an unmarked crystal, paper dial and still with it bow. only missing it's second hand.
I was surprised to find it wanted to work although only just about, so I thought I'd give it a go. Somewhat nervous as I've never worked on something this old, if my interweb research is correct it dates to around 1910 or thereabouts.
After a lot of deliberation I carefully dismantled it, puzzled as to how to get it out the case and let any remaining power down (interweb helped here with some clues).  I had pictures of the thing exploding in my mind. The rust was tricky to deal with, but it had to go, sadly I lost some of the bluing, but after cleaning (filled with dirt and what appeared to be fine metal swarf) and lubrication things were looking promising.
I stopped myself breaking the tin of Brasso and a bout of polishing frenzy, on basis it took years to look like it does and it's never going to be brand new after 100 years or so. I'm glad I did as the patina feels right.
It's been running well now keeping time as it should, and actually winds and you can set the hands. On the lookout for a replacement second hand, to finish it off.
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
