I decided to play in the 404 club and was able to land this gem.  I think I am allowed to exclude shipping in the 404 number.
This is an AS 1187 movement--the 7-jewel version.
It is a very simple movement, but I had some problems.
1) For whatever reason, I had a lot of problem rewinding and installing the mainspring.  Couldn't get the winder to catch, set the winder diameter too large and and to start over, through the process, I managed to open up the inner coil.  Worried that the arbor would not engage, I re-shaped the inner coil.  Fortunately, I have the proper tool to do that.  The final attempt was a diving catch in the end zone.  The diameter I set gave me no margin, but I popped it in.  Since my recent watchmaking revival, I have done this maybe a dozen times with no trouble...not today.
2) Normally, when I drop the balance assy in, it just takes off running.  This time, the roller jewel kept getting on the outside of the fork horns.  Grrr...frustrating.  Finally got it in.
I did not separate the balance from the cock, nor the hairspring from the balance in order to do any truing test or poising.  However, once installed, I could visually see that the balance was perfectly true.  Poising...dunno.
I made regulation adjustments, but found that there was variance in different positions.  The usual suspects I guess, but I did not check.
There were two goals in this excise:
1) Follow through with a 404 purchase (buy it and fix it)
2) Improve my watchmaking skills.
I am getting better...but...miles to go before I sleep.
2021-06-27 12_28_56-Geneva Incabloc Vintage swiss Antimagnetic Unbreakable Mainspring Watch _AS-IS_ .png
Cheap and cheerful! 404 for the win! A nice, high dollar watch is obviously a nice thing, but there's an element of stress to it that is totally absent with a 404. Even if you screw it up wildly, you're basically no worse for the experience. I know it's often suggested to start with pocket watches, but this is definitely where I'd point someone wanting to get started. Takes all the stress out of it.
"Worried that the arbor would not engage, I re-shaped the inner coil.  Fortunately, I have the proper tool to do that."
What is your proper tool?  I've been using tweezers, and my technique is poor.  Thanks.  Well done!
