Introducing myself!
Hello everyone,
my name is Álvaro and I'm from Portugal. Professional musician, I'm also a watch collector and watchmaking enthusiast being that my father is a retired watchmaker (old school ie., no parts? Make it yourself!)😄. At the moment I'm gravitating around the Seiko brand and it's most common and less expensive vintage calibers/models. Like this one, 2107-0120 small size model. A bit frustrating as I can't manage to get it out of the case. Or I'm doing it wrong or the movement holder ring is really stuck!! 🙁 Help is much apreciated!
Cheers!
Welcome to WRT forum.
 I can't tell if there is a rubber O-ring there, I pull out the stem to set position, press on set lever button and remove the stem, insert a driver in the hole stem was in, pry the retainer plate/ ring out.
 That rubber ring has to come out, thats whats keeping the retainer plate so tight in place, it migh come out in pieces, take a soldering gun to it if needed. needs to be replaced with new one anyway. with stem out , just stick a screw driver into hole of the retainer plate  pry it off against the case
Good luck.
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
