My Watch of the Day
I’m not sure where my pictures went. I guess I’ll repost. I sincerely apologize for the double post. I cannot figure out how to edit my previous post or why my pictures aren’t showing up.
Seiko 5 Sports SpeedTimer Flyback Chronograph:
Edited by PinLeverPete
Today I'd like to present a Timex 202, all original. This is a very rare piece.
The module had several damaged wire bonds, but I only took a few pictures. The second picture shows the damaged wire bond on the lower colon before repair. Fixing wire bonds that are broken off of semiconductors takes silver paste and a brain surgeons steady hand. 😄
Another Timex. I believe this one dates to the early 70s based on the EB 8461-73 one jewel movement. Strange, this one. The one jewel is the roller.
I don't wear finger cots or use movement holders when disassembling cheap pin levers...only on reassembly. Fire away 😄
Purchased as never worn, new old stock, the first photo shows how it looked when it came to me. Unfortunately, the lower balance staff pivot was broken and the cost of a new balance and/or staff was more than the watch. After sitting idle for 2 months, I found a Sicura watch with a 17 jewel EB 8461 movement for $10. I swapped the jump hour parts over and now my wife has the only 17 jewel Timex jump hour (maybe). 😉
The first photo in the next post is how it looks now. It is beautiful and runs silky smooth!
I’m still waiting on the parts movement to fix the Lucerne chronograph above, so I did another of these last night (the one on the left). I’m starting to worry a bit. It’s been two weeks since it landed in Chicago (maybe it’s Chicago’s mail?).
Fully serviced, new crystal, the works...
Another eight hour marathon 😄
The Lucerne chronograph is off the table for now. The parts movement is no good.
Latest Timex model 87 (1970, West Germany Electronic Durowe cal. 882). I’ve discovered two significant modes of failure on these:
The first is a weak arresting magnet for the index wheel (understandable as they are 50 years old). This allows the index wheel (I call it the ninja star...it will disappear like a ninja, too) to backtrack too far when the index lever (like a pallet fork) retracts. Essentially, the movement ticks like its running, but the second hand won’t move because the index wheel is not actually advancing.
The second is a weak capacitor in the control circuit. Again, 50 years old, so not surprising. The 220-250nf capacitor holds a small charge generated by the balance coil during its initial stroke, releasing that charge on the backstroke to drive the balance. A weak capacitor results in low amplitude, again causing the watch to tick, but not advance the index wheel or second hand. Replacing the capacitor solves this issue.
  • 4 weeks later...
  • 4 weeks later...
I've been busy...rebuilt 25 or so Timex Electric and Electronic watches in the last month or two. 32 more in the que. I heard there's some guy around here that likes to shoot the movement with contact cleaner and call it good. That's a shame. I can fully rebuild one of these, including wet sanding and polishing the crystal, in about 3 hours. No need for cutting corners 😉
I am the Timex whisperer 🙂
Some...
15 minutes ago, watchweasol said:
A fair handfull, nice to see the TIMEX is well represented and not treated with scorn, they were in their time innovative and ahead of their time well worth keeping the name alive.
I absolutely love the Electric and Electronic models. Easy to work on, great runners and gorgeous.
Some more that I've posted around the forums (personal collection):
This topic is now closed to further replies.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
