Hi-
I'm new to this forum and looking forward to participating. To start off, I am in need of some help/advice.
Working on an Elgin/18S, Grade 10 - s/n 1911886. The upper fourth wheel jewel has been shattered - it's completely
gone. I believe this jewel was rubbed in, but I don't think I can replace it with same - the "lip" that would be used
to secure the jewel is damaged :(. I believe the only realistic way forward is to replace with a friction jewel.
My specific questions:
o The pivot size is 0.31mm --- what size jewel hole would I replace this with? Would it be 0.32mm???
o I have an old Marshall jeweling set, and in order to fit a friction jewel I would need to use the reamer labeled #10.
I have left my home for the day and wanted to order the replacement jewel today. Unfortunately I'm not certain as to
what outside diameter the #10 reamer corresponds to :( If someone knows that would be great - else I will just measure
it tonight when I return. I think I would need to order a jewel with outside diameter 0.01mm larger than the reamer size???
Many thanks!
Stu...
Hi Stu,
Interesting question and since I've been entertaining to start working with my jeweling set, I will anxiously wait for the experienced people to chip in!
cheers,
Bob
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
