Chunky golden nugget
Good evening,
I thought I'd share my latest achievement. I'd been building up courage to take on a day/date watch after my previous success with an automatic. This unloved golden nugget came to me as a non runner and fairly grubby.  With one of those Russian Slava 2428 movements with the double spring barrel arrangement.
Thanks to my cheap ultrasonic cleaner and the great advice I received on the forum to safely polish it. It buffed up a treat. Sadly the innards had suffered from an excess of oil, which had damaged the balance spring, and the day wheel, where the painted finish has started to lift off. It also affected a small area of the dial. Though everything else was well preserved in the oil and gunk. In my short time tinkering, is this a common problem others come across?
I found the trickiest part was the shock jewel springs. After setting time aside to only tackle these on an evening and nothing more. I managed to get them back on with a combination of tweezers and a sharpened toothpick. I had a hell of a time with even the finest pointed tweezers.
The problem is I'm not brave enough to wear it out of the house. It's too extravagant for me, I may view it differently when I get round to finding a better strap than the cheap canvas one its sporting.
Lol! I can relate. The first watch I successfully rescued (though technically I still need to order a stem and crown) is a big 70s gold bling bomb with a green dial. I have been calling it the "leprechaun pimp" watch. It's hideous, but after all that work and finally succeeding... It's really just too hideous.
Thanks Spectre, I'd love to see the "leprechaun pimp" watch if you've a photo by way of a comparison. Unless it's too hideous its an offence to watchdom! Despite the looks of my "golden nugget" I'm pleased nonetheless with my success. Out of all the watches I've tinkered with this one by far keeps the best time.
I'll have to wear it in secret, unless there's a 1970's fashion revival at which point I'll fit right in.
Love the green dial, with those white hands it's got a minty thing going on. It's begging for one of those gold elasticated straps.
When you finish it, wear it with pride, possibly when no ones looking. Still building up courage to wear my one. Certainly a conversation piece. ?
  • 7 months later...
On 3/18/2021 at 8:33 PM, Bearman said:
Good evening,
That is a Golden nugget!
Nice job.  definitly need to source a nice retro gold plated strap for it.
I'm interested in hearing about the cheap ultrasonic cleaner, as i do need to get one and should be able to justify the investment if its a cheap one. I can tell my wife i've purchased it to clean hers and my daughters jewelry. 😁
Thanks both, I've been thinking about a strap for a while now. Not a fan of those hair pinching elasticated ones from the era. Out of all the watches I've tinkered with over the last year or so it keeps the best time bar far.
Stretch, that's the exact same reason I used to justify my cleaner! It certainly made things that bit easier. Mine came from ebay around £30, I made sure it was mains powered with an adjustable timer. Used it loads with tiny jam jars containing the parts and cleaning fluid.
I've a number of other Sekondas which I've brought back to life, all with that 70s vibe. I'll have to get round to showcasing them....
Hi Bearman, There are far too many cleaners to choose from, bit of a minefield for picking a rubbish one.  Any chance you can let me know the make and model of your ultrasonic cleaner, as i'd rather go with one that i know someone is using.
cheers
    • Did you have a look under the ballance? Often the movement maker/number is hidden there.
    • I wonder if 9415 is based on a base oil of 941? it's interesting what questions bring and the tech sheet answers it's the viscosity of the base oil. Then the impact? There is something we're missing here for that which would have a big influence on all of the house image above is 9514 image below is 941.then always interesting when specifications do not exactly agree? They ledge above for 941 indicates 110 viscosity but the image off the spec sheet is slightly less but I guess close enough   my understanding of the concern of too much 9415 is as we know the loss of amplitude. But why do we have a loss of amplitude? So impact it's basically oil should be very slippery. But what about non-impact? Like the edges of the escape wheel? Another thing that comes to play here is the shape of the escape wheel itself. Notice on the last a more vintage escape wheel with just a flat surface whereas the modern escape wheels usually made out of steel versus grass much much thinner their contact areas greatly been reduced and sometimes I think there even slightly curved. So is it conceivable at everything that isn't a flat surface on impact is going to be sticky? So this is where the shape of the escape wheel will have a big impact literally on how slippery things are. Oh and for all of you obsessed with worrying about too much 9415 I never worry about it because typically I'm doing pocket watches and it doesn't seem to be an issue at all. on the other hand I'm much more concerned about a watch that keeps time for 24 hours as opposed to the concern of the group of keeping amplitude for 24 hours. Then yes some pocket watches have steel escape wheels and do look like the escape wheel on the right.
    • your balance wheel looks interesting in the watch and because it's at an angle it's changing things a little bit. in other words they hairspring is not centered between the regulator pin in the boot and I also noticed your terminal curve is lacking apparently by design? Because if you look in the second image you'll notice yes there's a terminal curve but not as aggressive a one as you normally see on watches at least most watches.   then in all of your images it looks like the boot isn't quite back where it's supposed to be? out of curiosity how did you remove your balance complete and clear the regulator pin? then just in case you weren't aware it rotates out of the way so you can remove the balance complete without bending the pin. Then it's rotated back exactly 90° and yours looks like it's off by just a little bit in the original image and I'm assuming that you just been the pin out of the way? it's always interesting in horology is the variations in the things. Like the image I have above does have a terminal curve but not the most aggressive and yours is even less but that is the way the watch was made. Then the spacing between the regulator pin in the boot should be relatively small basically if you had two pieces of the thickness of your hairspring that's how much space should be there like in this image. But oftentimes watch manufacturers do not necessarily follow the rules
    • Yep i can see where you're going with that one Rich.  Sooo now that I've frightened the OP into submission 😁. Chief i do apologise for some reason unbeknown to myself I'm in a happy silly mood. So seriously to identify the movement lets have a look at the dial side, learning this part is straightforward, just need a little logic and something called the # BESTFIT BOOKS # . Or the other non American equivalents.
    • I can definitely see elephant and aardvark and possibly some sort of bird with a large beak 🤣 anyway I'll have a go of getting it flipped over tonight and send some pics
