Here is a broken staff from an inexpensive stopwatch.
This will be my maiden voyage into making a custom staff with my lathe.
As you can see...this does not use a jeweled roller table.
I think that this staff is one solid piece of metal, so I need to start with stock equivalent to the largest diameter of what you see here, but I am not sure.
What should I start with in terms of raw stock?  I have various kinds of rods that were passed down to me.  I also have some old clock balance wheels that I could steal the staff (if the diameter is great enough).
Thoughts?
2 hours ago, JohnR725 said:
I appear to have failing eyesight or I lack proper imagination to grasp what you're trying to say? Or maybe a picture wasn't attached.
There is a good reason for that.  I failed to post a picture.  No matter...I have already begun the task using some round steel stock I had in the watch bench.  I am about halfway done...hoping not to screw up.
There is always the tiny possibility that we can get a replacement and deny you your fun of making one.
Then it's a shame it wasn't the right kind of stopwatch? Some stopwatch is have spare parts. Their hiding so I went online and snipped out some pictures for you. This particular example actually has a note that the parts are hiding under something. Other times it's not at least I remember it's not always shown that this is where the parts are hiding.
I put lots of hours into this.  First try fail, second try stopped at this point--one pivot turned, but not the second.
The issue is the damn slot.  On the first try, I used a dremel--not a precision instrument, but it was pretty close.  Then I had a fail later in the process.
Second try, looking good, but not willing to go the dremel route again.  So, I am scratching my head and pondering a precision way to make the slot.
    • I have not attempted lume repair before but the idea is interesting. The uv glue might not bond directly with the old lume. I would probably mix the uv glue with a few drops of acetone before applying it to the old lume. The acetone would soften the old lume and allow the uv glue to diffuse into the surface and meld with it. Then allow a few minutes for the acetone to evaporate before curing it with uv. Most uv glues and varnishes have a layer of uncured resin that is caused by contact with oxygen in the air. This is the reason for the sticky surface after curing it with uv light. This uncured layer can be removed with IPA or by fully curing it by painting a layer of glycerin as the final layer to prevent contact with air, then curing it with uv.
    • Additional information for you,   Have a look at the watchfix courses by our administrator. Mark Lovick for a little more in depth training. Watch_tools_tipps.pdf TZIllustratedGlossary.pdf
    • The key is to try and find what the movement is and if there are no other numbers or markings on the movement then the next step would be using the like of BestFit based on the size and keyless works. The top one below is a Normal Bridle with no kind of end termination. What does the existing end termination look like.
    • Daniel, I guess You actually asked if the accuracy of the watch was improved after jewels added. One would not expect such accuracy improvement. The watch accuracy depends on many things and most of them are related to the balance and escapement. Well, it depends what is considered to be a no jeweled watch. If this is pin pallet watch wit cone balance pivots, then, believe me, replacing balance staff with one with cylindrical pivots in jewels will only worsen the things. Cone shaped pivots in cup bearings actually work better than  cylindrical, the only problem is that they wear faster. And, it will be hard to impossible to replace the pallet pins with ruby pins... The watch accuracy depends maimly on the balance and escapement adjustments ad it is no related to the presence of jewels. Adding jewels to the train wheel bearings may only lead to some amplitude increasing, and it is not sure too.
    • Thank you so much! I'll experiment a bit with the UV glue and chalk and maybe eventually try to fill the hole.  I'll report back!
