Old Roamer Anfibio case problem.
Flubber
Hi all,
I bought a really nice ladies watch in an auction (20 £) and I had great problems opening the case back. When I finally got it opened,I was puzzled since the whole movement was snuggly fitted into case back that was actually more than just a lid to open. I'm beginning to suspect that the watch was really intended to be opened from the glass side (like the Omega Cosmic). Any help on how to get the movement freed from the back so I may service it would be greatly appreciated.
Edited by Flubber
Looks like a two piece or "split" stem. Roamer used this type of case quite a lot.
Try turning it upside down and slowly turning the crown. If you're lucky then when the joint between the two halves of the stem is aligned vertically the movement will just drop out, make sure that it has something soft to land on.
If this doesn't work then you will need to pull the crown with enough force to pull the two halves of the stem apart, releasing the movement.
It might be a split stem.  If you hold the whole thing upside down and slowly turn the crown, you may find that the dial and movement fall out the front when the split stem is oriented properly.  In theory you could force the crown out but if I'm wrong, you might damage something
It too looks as if there is reflector ring around the perimeter of the dial. I suspect this is just friction fit in the case to help hold the movement in place. Use a sharpened piece of peg wood or plastic pic to try to pull this up from the dial before proceeding as others have suggested with the stem/crown.
Edited by Repivot
Indeed, you were all correct. The movement did not fall out by itself but after pulling the crown (surprisingly hard) the stem split in two and after removing the reflector ring as suggsted by @Repivot I managed to get the movement free. A beautiful movement almost in mint condition. I should NOT have removed the case back and I made som scratches on it in my attempts. Well, You live and you learn. Thank you guys !
Edited by Flubber
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
