Hello, I have an old zenith 411 which is basically a 410 without moon phase only used by Concord in the impresario as far as I can tell. The reason I need it is broke the balance pivot. I am finally getting to repair it and I found some balances but there’s so many ancillary part numbers and I cannot find a sheet to pinpoint exactly which one to purchase. The balance number on all the technical sheets I have is 721 and if you go to cousins they have 721 balance completes available but they have different variations and I’m unsure which one to order. Any help from anyone out there who could help me refine which one. I’m either going to buy a balance complete with cock or balance with hairspring. Some other information on the watch.
it has 100 teeth on the fourth wheel (400z series is different)
21 teeth on escapement (400z series is different)
31 jewels (420 is 35)
36,000 vph
from around late 1990s
this is all the information I can think of off the top of my head but if you need anything else let me know.
Thank you
I searched the Cousins site for Omega 410 and only one balance assy. came up. OME4101327. If your 411 has Incabloc shock protection, this would be the one to get.
Thanks but it’s not omega it’s made by zenith it’s a zenith El primero  chronometer chronograph. It’s actually very similar to the zenith movement they put in the Daytonas back in the late 90s except Rolex put in their own balance and rolled back the vibrations to 28 800. I think part of the problem is it seems zenith lists all their balances as 721 for the part number, even some very old ones. I am working on a line to get one through Blake at Scotch watch and I’m hoping he has it because I’m not sure if any of the ones cousins have will fit mine. Either way I was hoping someone would have a parts list to find the part numbers because you can’t find much on the Internet.
Hi Ihave attached the following documents on the Zenith, There seems to be nothing specific on the 411 as the base caliber is the 400/410.  hope they are of some use to you in you endeavour     cheers
Zenith 400, 405, 410, 420, 400Z, 405Z, 410Z, 420Z.pdf 1.89 MB · 1 download Zenith 410 (1).pdf 858.75 kB · 1 download Zenith 410 El Primero.pdf 6.77 MB · 1 download 1984529516_Zenith400(2).pdf 41.86 MB · 1 download
Thank you I had the first couple documents but that last one gives me so much information on the servicing of the movement.
I think I found a balance with hairspring from Blake at scotch watch. The collet is a little different but it has the same amount of coils and the same termination area as far as I can tell so I think I’m going to pull the trigger on that and hope for the best. it is out of a 400 series and I think they’re all pretty much the same with minor differences such as a different collet. I believe they didn’t change the pallet except on the new models so I think I’ll be OK with the impulse on this balance. I tried removing my hair spring  but the collet is a three star very thin type and I ended up with some damage so I don’t want to  have to remove hair spring on one of these again, it’s not a standard brass ring and very fiddilly. Thank you for your help and if you know of some other resources for parts let me know I’m waiting for a picture of the impulse side of the balance before I pull the trigger.
Oops! Sorry! I think I should give up posting before breakfast.
I noticed that the parts list I have for the 410 of course does not have the balance wheel. Refers you to the base calibers 3019 PHF. Then the balance wheel is number 721 but? One of the problems with the Swiss numbering system is 721 is a balance wheel. But that part number does not tell us which balance wheel. For instance I'm looking at  AS 1940 Its balance wheel is 721. So basically any older tech sheet for just about any watch is going to Have the balance wheel 721. Which is why you needed additional numbers like the company name and the model number. Later the watch companies got smart and they have unique numbers.
To give you an example of the 721 problem I went the best fit online and just looking for Zenith parts a scroll down to the balance wheels which of course are 721 a snipped out a section just see you can see all the balance wheels are 721.we do get the best fit part number for your balance wheel plus perhaps a factory number.  The numbers that were interested in our ZEN 3019 PHC    721/1933    721/ZEN 3019. The first is the base caliber the second is the best fit number. The third is the factory number.
Then I'm attaching another image the interchangeability list which is interesting because basically there's almost none. But I'm guessing that's because all the variations in the watch basically still use this as the base caliber. As opposed to listing all or parts separately. Not sure if that makes any sense but at least to get a best fit number. Which is helpful for the US material houses where they might actually have one.
 Although knowing the number now is one material house it looks like you can scratch off the list and the balance wheel was pricey if they did have it.
Another option I haven't even looked for that is what about replacing the balance staff that would be considerably cheaper then the balance wheel itself?
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Zenith_410
Thanks John. Yeah I noticed how 721 seemed to just reference the fact it was a balance and that it was the universal number that just referred to balance part on a movement in general. So basically no matter the movement the balance would be listed at 721 like you said but trying to find the additional reference numbers for the part was impossible. Thank you for helping me out with this and I got really lucky with someone I trusted having the part because if I had to start shopping other sources I had no numbers. I was going to do the balance staff but they do not use a standard Collet but it’s more of a collapsed piece of thin metal and a three star pattern so when I tried to remove it I ended up damaging the hairspring a little at the attachment to the collet. It was hard because when using my Collet tools it was not possible to have any large surface adjacent from each other to lift up on. I have played around with repairing hair Springs but I really want this watch to be tiptop so I ruled it out. Not to mention I’ve never repaired a bend that close to the Collet. Fortunate for me I was able to source a balance complete for a zenith 400 series from Blake at Scotchwatch. Like you said it was pricey but it was better than the alternative of sending it off to have the service just to get the part. Happy to say I got it back together and it’s running with about a five to six second variation in positional error, Not quite chronometer spec but I’m OK with it.
    • Thank you Mike for the hints! I did go to HS Walsh and buy few tools that will help me start 🙂 I also went to the Royal Observatory at Greenwich, I saw the collection and it is amazing!! Harrison H4 is indeed an amazing manufact, and the story behind it (about the prize from the government) is incredible. Again, thank you for your suggestions, you made my day!
    • Hello watch enthusiasts, I'm encountering a peculiar issue with my Seiko 4006 movement and could use some advice. Specifically, the alarm bolt yoke doesn't function properly when I tighten the screw on the calendar plate directly above it. This results in the alarm not functioning as it should. However, when I leave the screw loose, everything works perfectly and alarm bolt yoke is functional as should be. I've tried replacing the alarm bolt yoke, the alarm bolt yoke spring, and even the calendar plate itself, but unfortunately, none of these changes have made a difference. The only workaround I've found is to keep the screw on top of the alarm bolt yoke loose. Has anyone else experienced a similar issue or have any insights on what might be causing this? I'll also be sharing pictures to help illustrate the problem. Looking forward to your suggestions and advice! TT
    • Some news. After screws removal from donor movement, a family shot. From left to right: original (broken) screws new screws purchased from Cousins UK, as "Slava 2428 clamp screws", that didn't fit. They actually & definitively look too large screws removed from donor 2428 movement Here we go! First one is in position: Let's continue on the other side: Done! Next step will be putting back the hands. Another discovery for me! I keep going ...
    • OK, I have been there many times and know several solutions. As I believe, the pinion (the part with the leaves ) is on the other side of the arbor, yes? If so, then there is easy way to solve the problem. You can grind from one side as shown on the drawing with dremel tool. This will allow to push out the broken drill bit easy from inside. Then You will be able to insert new pivot and then You can solder it in place and in the same time to fill the ground portion with solder. Of course, I mean solder for PCBs, but not the led free one - use led containing solder, the led free solder which is offered in common hardware stores is for idiots.
