Radial brushing technique
So putting lubrication on top of epilame is bad, it would bead off and not stay where you put it. -
That link is so cool! I will read through it as it looks like interesting reading!! Thank you.
I've never done it, however just today I was reading about it! P.24 - P.38 of this explains the truing procedure for damaged balance wheels. I have no idea if this is still the accepted way of doing it, the learning material is rather old 🤣. Hopefully one of the veterans will be along to give you an easier solution. Good luck Joseph Bulova School of Watch Making.pdf
Thanks for the feedback. Hopefully it won't happen again, but you never know.
