Ricoh 61 Lift Angle 49 degrees
Not really a question but hope it can help someone.
Well I did a bit of dynamic poising of a Ricoh 61 and needed to know the lift angle. To cut a long story short, I couldn't find the information anywhere.
Using some knowledge I found on this board I adjusted the mainspring so that the balance was moving 180 degrees and then adjusted the lift angle on the Timegrapher so that the amplitude was displayed as 180 degrees.
The lift angle was determined to be 49 degrees.
Hope it helps.
Any special trick to determine when the balance wheel is swinging 180 degrees? I would assume you measure from the point of impact of the impulse jewel, and that being a few degrees off would be OK? I guess making a small mark on the main plate of where a balance wheel spoke is on the point of impact could be a method?
Any reason you needed to know the lift angle to perform the dynamic poising (which I haven't yet tried)? Perhaps the lift angle affects the reported rate of the timing machine?
Thanks!
Thanks!
Hi, to see the 180 degrees amplitude is easy as the Ricoh 61 balance has two arms. As the arms reach the end of their travel, just before the motion reverses you will be able to see the arm on the rim of the balance momentarily stop. When you see a perfect overlap of the two arms at the end of their travel you will be at 180 degrees.
It's very important with dynamic poising to know if you are above or below 220 degrees. If you are way off with the lift angle then you could believe you are below 220 when you are above or vice versa. You will end up removing weight from the wrong side of the balance. Don't ask me how I know that ?
Edited by steve1811uk
Corrected 180 to 220
  • Thanks 2
Excellent, and crystal clear answers @steve1811uk. Thanks! ?
Here's an interesting thread discussing poising including illustrations of what happens at the 220 degrees "magic" amplitude.
OK, I won't! ?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
    • I opened up a 17 jeweled Swiss made movement only to find it has a pin pallet escapement. Not sure where the 17 jewels are but they ain’t on the pallet fork! Tips for lubrication?
    • Hi, This headstock is a little bit too modern for me to know my way round it. The pin that stops the collet spinning is sheared and needs replacing. Does anyone have advice on how to remove the spindle? I’m assuming that you remove the quick change assembly from shaft. Remove pulley. Unscrew front and back bearing plates on the headstock. Then press the spindle out applying pressure to the front (collet end). Has anyone done one of these? Any pictures or links to articles/literature gratefully appreciated. Thanks in advance. Warm Regards   Andy
