drilling oscillating weight core.
Good job. 👍 To my eyes, the centre of the coil is about where the red dot is. So a tweak at either of the arrows (as per the Chicago School) should centre it. It's not far off, and if you already have it installed , I'd run it and see how it performs.
By darkhelmetlive · Posted
I was curious about that, and last time I changed the battery I checked and both insulators are definitely there. The little arm that extends up away from the movement to touch the speaker seemed maybe slightly misaligned. I wondered if it was touching something it shouldn’t be, hence my parchment paper experiment. I also considered maybe just removing it as I believe it’s a single screw. Another thought is I have a service manual PDF for it and it has some testing instructions with voltage and other numbers, I might try some of those to see if something is obviously wrong. I see weasol probably posted the same PDF. All that being said, it might just need a service, as several of you have said, which I’d probably try to find a professional for. I’m don’t know that I feel like taking this thing apart too much. -
By EtherJunky · Posted
So I've been lurking on the internet again and found a rabbit hole to explore. I was able to download 5 pdf's about Soviet watch repair. They're all in Russian and are scanned images, so unlikely to be useful to anyone that doesn't speak the language or is able to use some form of artificial intelligence to translate it. I just thought it might be of interest to some of you. А.П.Харитончук Устройство и ремонт часов.pdf Д.Д.Карл - Сложные часы и их ремонт.pdf Дональд Де Карль - Руководство ро ремонту часов.pdf Ремонт часов, 1968 - Пинсон.pdf Харинтончук А.П. Устройство и ремонт часов.pdf 6 pdf's* [A._P._Haritonchuk]_Spravochnaya_kniga_po_remontu_(libcats.org).pdf -
By LittleWatchShop · Posted
I did purchase of Elgin 16s the other day, I think one of them will work, but I have been focused on this Rolex bezel until now...maybe today I will see if I have a winner.
