Hi, I hope you all are fine
Those days I found an old omega f300 cone case sleeping on the drawer polished as a mirror when I bough it, many years ago cheap as scrap.
I decided to give it a try and among other tasks, rescue it's finish, and discovered that it's impossible to do it by hand, each run marks his scratches in a different direction giving even worse impression than mirror polish, so decided to take the challenge of scratching it in a radial and homogeneous pattern.
I read somewhere a post about redoing an Omega cone surface, and found it really difficult, doing supports, regulators and so on, and requiring even a grinding machine, impossible and not to inspiring for me.
Saw even someone using a dremel that took the hell out of me.
Below it's the simple contraption that allowed to do it, maybe you can find it useful for your projects, it's cheap, easy to build and makes the redo a piece of cake.
All the secret is to guarantee that sanding paper (or whatever you use) attacks the surface always in the same "radial" direction, this is impossible if you grab the case or sand paper by hand, any minor deviation will shine as a photo flash ruining the look.
So to do it you may elaborate a complex rotating support, or take a simpler approach.
As the watch is round, almost any "support" that "fills" the case will allow to rotate it around that position keeping the angle and relative position of the case.
So with just a few sticks laying around I've been able to "build" a really simple "fill" to firmly support the case in a fixed position, allowing it to rotate freely but preventing any displacement up down, right or left, so keeping the case in the same relative angle no matter how much you rotate it.
The second challenge was to make a sanding "device"  to scratch the cone wall without any lateral displacement, so, just up and down motion along the cone wall, with any lateral distraction.
Again an old lumber piece and a single carpenter clamp did the trick.
Below are a few photos of the job, cheap, easy and efficient, I hope you find it useful.
It was fun to repair a watch case with lumber, sand paper and carpenter tools, still thinking what use give to the hammer.
My apologies, but don't know how to lay the photos in their  place
Ask if any doubt.
Cheers and take care
Ricardo
11 hours ago, steve1811uk said:
That's a really nice finish. What type of abrasive paper did you use? Manufacturer and grade?
Hi Steve,
Thanks for your comment.
I'm really not sure which brand it's , as per the shape and touch I think it could be 3M wetordry sand paper, possibly 500 grade, used dry, but again not sure, as it was a tiny piece lying around that I used to test, and liking the result decided to go ahead.
Any sanding paper will do as it only lightly scratches the surface with very little pressure. Maybe the only important thing is to use a good quality paper to avoid too much debris.
I think omega's original grind is a little deeper, but as it looked great didn't tested any coarse grade.
I hope it helps
Have a nice new year and take care.
Ricardo
  • Similar Content
    • HI everyone Some context: I'm "in love" with old Timex. As someone who has always liked watches, I knew Timex (my first watch and another project) but, in fact, the brand had never really caught my attention. By pure chance I bought, in a set of two others watches, a small m24 that was sold as not working (run and stop), which actually started working by setting the date by manually moving the hands (15 days). This coincidence made me interested in its history, its reputation, simplicity/complexity of the movements and also because some were made in Portugal back in 70’s and 80’s. A few days later I found this beautiful 1975 Viscount, m33 (very low price, almost offered) and this is where I need your help.  It is in very good condition and works well (-20s per day is not a problem for me), and although the day of the week changes correctly, the date is "stuck" on the 10th. I live in a small town that only has one watchmaker and when I purchased this watch (and having read about these movements) I thought that since it was something theoretically "simple" (probably not related to the movement), he would easily solve the problem. I couldn't be more wrong. It was as if I had proposed a pact with the devil. He refused and said he wouldn't touch the watch (although he had serviced several of my watches before - Seikos and old Swiss brands). He suggested I wear the watch like this or trash it. As I mentioned in my presentation to the forum, I have some experience in digital watches, but in manual watches I am a complete beginner. I know how to remove hands, crowns and little else. I've been doing my homework, reading the technical manual and watching a few videos on YouTube. I think I can get to the part of removing the dial without any major problems. I know that in the Date Frame there is a wheel that at the top has a tab that activates the Day Wheel and that at the bottom activates the Date Lever My aim is to try not to ruin anything and  get the date working again. The help I needed (I intend to post photos) is that what should I expect? What are the most common problems that cause this system to get stuck (in this case just the date).   PS -  My secondary objective is to buy a strap at a overpriced value from the watchmaker just to rub it in his face that I managed to get the watch working properly. PS2 - In the photos you can see that before midnight the day of the week is already changing but the day of the month has not changed.   Sorry about the english. Best Regards Vasco
    • What is it from and how did it become bent ? It should bend back - I would heat it whilst bending
    • Ha, same here. I just looked and I've lots of pictures of my cars, be hardly any of me - I have a face better suited for radio. I did find this from about 20+ years ago. I'm the young looking one at the back, under the front nozzle.
    • I have a 6564 with me what is take a same tropic 12 crystal,most likely have the same parameters for the bezel. Do you need the measurement for that?
