How to loosen cannon pinion?
Lc130
My 11DP beginner saga continues.  I've managed to press too hard on the cannon pinion while putting it on the center wheel.  I think the bottom jewel moved as end shake is high and amplitude dropped.  I have a donor main plate that I can rebuild. How does a beginner loosen the cannon pinion just enough to prevent moving the jewel again??
Helpless in Maryland
Charlie
If overtightened to the point it can't be preesed back on the arbour, you should broach it back to size.
In case you can press it back in place without damaging anything, but it just feels too tight, try adding a bit of oil, keep turning it as you would when setting time, this somewhat loosens it, remove, clean, grease and reinstal.
Hi Charlie,
In the old German and Swiss repair literature you find that it is good practice to support the bridge holding the centre wheel before you press on the cannon pinion. Ideally this is done with a staking tool. You select an anvil to rest the bridge and the jewel. Then you press in the cannon pinion with a hollow flat punch. I have never laid hands on a bulova 11dp but if the highest point of the balance side of the movement is the rachet wheel you will still have air between centre wheel jewel and bench. If you place it in a movement holder you have a lot of air between jewel and the bench. That's lethal and as you experienced can push out the jewel in a worst-case-scenario
I don't have a better picture on my mobile and you can't see the anvil under the plate. The cannon pinion of this pocket watch also looks a little different but you can see the basic layout. If you don't have a staking tool you can always rest the movement on a piece of steel.
Best wishes from Hamburg, Germany
Alex
If this was an original cannon pinion, then it should not require any excessive force while replacing it. Good cleaning inside, a little bit of oil on the centre wheel pivot, and a gentle push with tweezers straight down. Only once i had similar experience on a very-very old / crappy movement. What i did, i installed the cannon pinion BEFORE installing the bridge with bottom jewel. Yes, it was a bit tricky, and i did it under microscope while keeping the plate in vertical position, but it took just a few seconds using two punches from my trusted K&D staking tool. Everything was done by hands without using brutal force.
Under the microscope I was able to see that the bridge jewel got pushed in.  I compared it to a donor.  I swapped the donor bridge in and then did exactly as you did.  It worked.  Thank you for the tip.
I am glad to hear that my suggestion worked for you. I am about to replace a cannon pinion on Illinois pocket watch right now and will follow my own advice ? as the lower jewel is secured by three tiny screws.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
