Quick Service - French VAP Drum Clock
rodabod
I’ve never owned a VAP clock as I assumed they were inferior to the typical Japy Freres, etc. However, this clock is great quality. Fantastic finish, especially on the escapement parts (mirror finish on the pallets).
Anyway, I didn’t want to spend too much time on this one. It didn’t run at all, but the balance staff appeared intact.
This has a balance wheel which oscillates a set of deadbeat pallets on a conventional escape wheel - ie. the escape wheel runs in the same plain as the rest of the going train. It seems to work well as a concept.
The fourth photo shows the steel “endstone” for the lower balance pivot. This had been poorly cleaned and scratched previously and showed wear from the pivot, so I gave it a quick polish.
I went with pretty much standard wristwatch lubricants with this, albeit heavy oil (HP1300) was used on all train pivots. Time will tell how well that works.
The cleaning I did in two stages - L&R oil-based watch cleaner/rinse and then a final clean/rinse with Greiner water-based. The reason for the water-based clean was since the L&R was previously used for cleaning watches and left a slight residue. The plates had some corrosion marks but I chose to leave them  untouched.
A nice, simple clock, and probably a perfect starter for someone who is more used to wristwatches.
That looks good. These drum clocks have many types of movement from being very poor to the really good ones. Nice to see the pins used are all around the same size and cleaned up. The hand set and arbor look cleaned up as well, many clock repairers never bother ( I don't know why) I know I'm a fussy so and so I would have liked to have seen the screws polished and blued. The dial looks in good order, is it paper or enamel?  Moon shaped hands matching and original. Should be an 8 day duration movement.
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
