Vintage Lady Omega 2849. Help, Please
Hello Experts.
I just bought an vintage lady Omega. The spec is listed below.
Unfortunately, it is missing stem and crown.
I am confused about with stem ref which will be the correct one to buy.
Please give me your advise. Thanks
OMEGA2849
OMEGA TWO HANDS LADIES MANUAL WINIDNG WATCH
Feature : Two Hands and Manual Winding
Dial Features : Original Dial
Dial Color : White
Markers : Golden Arrow Figures
Case Material : Top Roll Gold Case With Stainless Steel Back Cover
Condition : Used and Excellent as per its Age
Sign : Signed on the Dial, Crown, In Side Back Cover and Movement
Authentic : All Watches displayed are 100% Authentic and Original
Crown : Pull
Band Type : Leather
Hands : Golden Hands
Movement : Manual Winding
Gender : Ladies
Machine No. : 620
Back No. : 511.215
Serial No. : 24587443
Jewels : 17
Case Diameter Size : 1.9 cm
Side To Side Size : 2.1 (Including Crown)
Vintage Ladies Omega Movement 620
Here are the list of stem ref that I found they are listing on eBay:
Omega winding stem ref: 620-1106, 620-1149, 620-1159
Thanks again.
Hi Johnvsd,
I just had a look on cousinsuk. They have 2 stems for the 620.
620-1125 -> 25.80mm (extra long)
6220-1106 ->  12.20mm
These are both 1 piece stems
620-1159  is a 2 piece movement stem
620-1149 is the negative part of the 2 piece winding stem (the inner part)
So everything depends on the case design. If the movement comes out from the back you can use the 1 piece stem.
If the movement comes out from the front  and you can't 'unlock' the stem through the back, you need the 2 piece stem.
In your case, the 1 piece stem is the one you need. I guess the normal length should do, but it's best to measure this to be sure.
Edited by PeterGe
