Hello all,
Does anyone know where I could procure this part? Universal Geneve 283 #8220.
The screw on the bottom of mine has broken off somehow or another. Attached is a photo showing the hammer.
If anyone knows of a way to repair this hammer, please let me know as well. Thank you!!
Be aware that changing the hammer may (will) produce malfunction of the hands reset.
I would remove the rest of the screw and mount a new one.
Frank
Frank
I'll give it a shot. Hoping there is enough left to grip for the removal.
8 hours ago, wls1971 said:
According to Urdelar.se it should fit
http://www.urdelar.se/universal geneve/Universal Geneve 281, 285 (14-15.75'''), Hammer, No: 8220?page=2
Why not ask the seller, if they say it will fit and it doesn't you can send it back under a item not as described return through ebay.
I went ahead and asked and he said'
'Hello, to my knowledge, yes. Maybe safer though if you check some other source...'
Sounds like I will roll the dice and get this as a backup.
