so, after taking a couple watches apart, cleaning and reassemble I have one that is stubborn.  Everything went well, it started right up after I reassembled it, but the balance wheel only swings about 45 degrees before it goes back.  The mainspring looked good and it contines to move on its own.  but over eight hours it managed to add about 1.5 hours.  I removed the jewels and cleaned, examined the shaft. What do I need to look at next. Even now it only swings a total of 90 degrees between each stop.
I would have started with checking the balance spring. If it touch the top of the balance cock "bridge" you probably have a bent spring or the spring lays not flat on the balance axel.
Morten
Yeah, I checked the balance spring and made sure the balance was flat and not touching.
Have you checked the spring for magnetism ?
Morten
My money's on this being the problem! :)
Have you checked to see if the spring coils are touching or are stuck due to residue from cleaning if so try dipping the balance in one dip or a substitute such as lighter fuel..
Best wishes
Darren
so got back home and looked at my fast watch, after 8 hours I had gained 5 minutes.. who voted for magnetized spring. Well, its alot better. Need to put that on my to do list before cleaning.
If it's gained five minutes in eight hours, there are still some real issues to resolve. Weak mainspring, are the pivots running free, contamination of the hairspring, to name a few.
Remove the balance assembly, let all the power off the mainspring and remove the ratchet wheel. Now take your air puffer and gently blow against the periphery of the escape wheel, it should drive the complete movement either way. If it doesn't then there is something restricting free movement of the train and will have to be investigated further.
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
