Winterhalder clock
Derk48
Who can help me?
I have a Winterhalder & Hofmeier clock with an ascending quarter striking. The clock is equipped with a stepped disc with bounce lever. The breech lift is solid, stuck, and there is no security for seizing at twelve o'clock.
When the percussion spring is finished; go through the work in progress and the breech lift lower and deeper. At the 12 o'clock stroke it will jam because the spring of the percussion is completely relaxed.
Today, the breech lift is resilient and slides over the treadle disc. I was under the impression that something was missing from this timepiece, but I saw a similar clock on the internet with the same construction. How has this been solved in the past.?
I don't get it and I really want to know.
Thanks in advance!
Derk
If you have the same Winterhalter clock i have in my shop for sale that i overhauled it is thus
Its a two train clock movement.  The strike train is rack strike.  But it strikes every 15 minutes.  I believe its called a petite sonnerie. BUT ITS A BIM BAM.
At 15, it strikes one bim bam
At 30, bim bam, bim bam
At 45, 3 bim bams
Then on the hour one hammer hits one coil to simply count the hours
    • Non-magnetic is a poor description of such a hairspring. A better description would be unmagnetisable hairspring. There are metals and alloys that are attracted to magnets, but don’t become magnetised themselves. A hairspring made out such a material will be attracted to magnetised tweezers, but will not become magnetised. These hairsprings can be disrupted by being in close proximity to a magnet, but the disruption will cease the moment the magnet is moved away. These are hairsprings that could conceivably be disrupted by a magnetised hairspring stud. Best Regards, Mark
    • More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".   So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x. However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance. What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
    • Modern ones after blue steel, invar, elinvar and nivarox , the shiny one are not supposed to become magnetised. But i have had them jump to tweezers. And i dont really understand the comment that what can be magnetised is the stud carrier and rate regulator and they can attract the hairspring ? If the hairspring is non magnetic then how can it be attracted to something else thats become magnetise, its non magnetic , that doesn't really make sense to be ?
    • Does it say 17 jewels on the dial or on the movement ?
    • Hello and welcome from Leeds.
