Not a quartz or seiko person but definitely a chrono person. The watch works but chrono buttons aren't all working.
Maybe I'll service it and see assuming its worth it?
Hey Geo, thats a stunnner, i like the first sentence, man of my own heart.  i have the 7a28 model, im not a seiko guy but like i said it looks great.
Is there any way i can find out the age of my one as if its 84 like yours i will be even more happier (birth watch !)
Your a wealth of information today.. July 1983 ... almost!
Ill restore this one, need to strop the movement down and see if i can diagnose the chrono problem
Thanks again
J
Well this may explain the pushers not engaging.
Gonna see if I can get some replacements today in london however i dont think anywhere is open :(
Edited by jnash
Scrap that, just reread, I'll try and save the pusher clips but I can't put the back the plate in as its the dial, I'll try and clean that up with a fibre bush maybe . keep you posted. I'm assuming the pusher clips are too far gone and will need replacement but I'll try anyway.. Off to tesco!
Just used baking soda, it took the edge off, see below
Then I progressed to l&r rust remover which made a dent too :)
Not bad, going to polish up the pushers see if I can salvage, thanks for the help, now onto getting the movement to function correctly!
Nice progress, jnash. Interested in the final result. I'm also wondering if there is any equivalent movement to the 7a28? Being Seiko, I've found lots of their cases each accept a few of their movement offerings...
Hi Bob, the 7a28 is an absolute cracker of a movement with great history. It was the first analogue quartz chronograph, and is well worth restoring from a historic point of view. In my view it would be sacrilege to fit anything else into the case.
Good morning Jonathan. I hope you are going to post a full and concise set of photos of the rebuild, I haven't serviced mine yet. ;)
Will do, polishing up the pusher clips after the rust removal this morning and continuing with the clean and build. I need to replace the glass and the gasket for the bezel. Do you know what the numbers are for these or will generics do? Thanks
I'm sure you would get away with generics, but some of the Seiko experts on here will be able to give you better advice. Q Blacklab & Bob! :)
Thanks Geo and jnash. As a restorer myself, I agree wholeheartedly.
Still the curiosity persists and hope the question is valid considering some cases are more compatible than others. I've seen "non working samples" of beautiful watches (everything included except the movement) but the original movement is not in production anymore and not worth buying used (for restoration). if I want to still get the watch to work I may need to find an alternative.
Also, I'm trying to put together some sort of "database" for movement interchangeability. Again, just to feed my curiosity not just of this fact but of  how the industry approaches new designs, tooling, etc...
it was going so well.......
rotary switch just flew off into the ether..... looks like i will need to source a replacement before i continue!
really annoying!
Sorry to hear that, its a right pain. As for the crystal, all the info you need is here: http://www.thewatchsite.com/21-japanese-watch-discussion-forum/35635-7a28-7039-crystal-replacement.html As for crystal gasket (nylon?) they are hens teeth on older Seikos, the part number is 86566600 and was used on 7A28-7030/ 703A/ 703B as well, try to use the one you have. If you do use a generic gasket you will probably have to use a slightly smaller crystal, as the generic gaskets are generally thicker. I have used a generic gasket on a 7002 diver with the slightly smaller 7S26 crystal and it fits well but its not been pressure tested.
Nice work so far, looking forward to seeing the finished item.
Thanks blacklab,
I think i can get away with the crystal gasket, so i need to get my hands on a replacement glass and the gasket that attaches the bezel to the case. had a look at the cousins site but bit confused with the seikos, is there anywhere else in the uk that will have the stuff if they dont?
Thanks
Jonathan
The bezel gasket (part number 8656.7680) are even rarer - can you post a pic we may be able to come up with an alternative. As for the crystal a 31.5x1.5mm flat round is supposed to fit and normally cost between £1-2. Try fleabay.
    • This is a screenshot of a video of it running. Not the best quality, though.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
