Hi,
I’m going to attempt to get what I though was a rough/beaten up Catena Spaceman up and running - or at least a quick inspection before handing over to a professional, but after closer look - it might be a fake.
No matter, I will crack on!
I need to get it open to inspect it - most certainly it needs a clean and oiling.
my first snag - how to get into the movement.
I don’t see anywhere obvious to remove the crown and stem.
nowhere on internet I can advice on this model all :(
Ideas?
What makes you suspect it fake?
It a front loader, two piece stem.
Pull the stem out to set position, place your tweezers between the case and the crown, pry open.  A nipper works too if you got one.
Reomve the crystal, pop the movement out.
Cheers, I’ll check to see if there are any videos on YouTube for that. How do you know it’s a front loader, two piece - if you don’t mind me asking?
thoughts on it being fake are:
1. It’s black black, not black-brown. From what I’ve read, there was never a black model of this watch.
2. So far, I’ve not seen any official variant that had Medana as the brand. My NoS version has Tressa Lux below the calendar - which is another hint...no calendar on this one either.
Even if it is fake, that alone will be interesting :)
Many brand names went on spaceman dials, movements are mostly AS and rarely ST 96. I am pretty sure you got a genuine piece.
Save the strap , impossible to find, any replacement would de-value the piece,  the crystal is rare and expensive polish it if you can,  the watch is sought after, though not as much as audessiuse version.
The case has no removable back.
Good luck.
Stem and crown off - is it a ziplock and syringe job to pop the crystal off?
Interesting comment on the strap. I have seen reproduction straps. As it’s a watch I plan to wear semi- regularly, I was planning to get a replacement, but obviously keep the original if I ever planned to move it on.
Polishing and cleaning to come after the mechanics obviously ;)
Disaster.
last weekend I put the partly disassembled watch on work tray, on my dining room table as in the mornings the light is perfect.
Cat saw me for once sitting at the dining table, and wanted to see what I was doing.Young dog got jealous - jumped to get the cat, tray got tipped over - and I heard something hit the window just behind me.
2h later I gave up trying to find the crown and stem :(
Lesson to self - my basement workshop might be depressing (it’s where I’ve worked every day during Covid), but it’s kid and animal free....
I keep meaning to restart the work - but I’m so annoyed that 1 second of cat/dog nonsense lost a watch part, quite literally inches from my head.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
