Need a balance staff for pocket watch
I have got some with J>140 but  A~620,  One would think to cut out a pivot on it at 580 on lathe. The measurements you gave are inexact too.
To do without lathe,  we both should do better homework.
I have set aside a number of possible candidates.
I’m now thinking of getting a lathe, I managed to get the A measurement by balancing staffs in place until I found the correct one. The other measurements I got from the existing staff. Thank you so much for looking through your collection you’ve definitely gone above and beyond. The movement is Swiss and doesn’t seem to conform to a standard size, I could potentially ask a professional to trim an existing staff to size, I would love to buy a lathe and adjust one myself but money is definitely tight during lock down I have a feeling that this project will be ongoing for some time. I suppose being patient is a good virtue for a amateur watchmaker :)
On 6/10/2020 at 2:17 PM, JohnR725 said:
I don't suppose you have a picture of the dial side showing the setting parts?
Then the website below you can enter in dimensions see if anything matches or if anything's really close because then you can just modify it. Like very first one on the list Buren (BAA) Looked relatively close. Another place to look is the bestfit book Which also has a listing of balance staffs by size.
https://www.balancestaffs.com/product.php?dim_A=580
Neither I nor Daniel have lathe to do the modification. he can modify J & G with a broach and I haven't come across anything suitable yet, begining to look into other options.
Edited by Nucejoe
balance staff let you enter A & B only.
1 hour ago, Daniel123 said:
Not sure if this helps but I've been doing research and the movement is a IWC Swiss made and imported to USA not sure how it then ended up in Wales but it must have had an interesting history. :)
Weren't IWC movements made in-house? Did IWC source staffs from Ronda?  I think I should have found an exact matching one by now.
ok it looks like IWC made the case and Droz & Perret made the movement, a few people are suggesting that Droz & Perret was part of Longines? the movement has St Imier on it. Ive been looking on balancestaffs.com and there are some very close matches on the Longines list.
On 6/11/2020 at 9:26 PM, Daniel123 said:
Yeah it’s a bit frustrating you can only search by A & B then you hit return. The list should show up below then it’s a case of clicking on each of them to find the best match.
Thank you Daniel, I tried that, worked.
    • Could it be an abbreviation for Denier? "Denier (/ˈdɛniər/) or den (abbreviated D), a unit of measure for the linear mass density of fibers, is the mass in grams per 9,000 metres of the fiber. The denier is based on a natural reference: a single strand of silk is approximately one denier; a 9,000-metre strand of silk weighs about one gram." The pivot gauge looks interesting, however I wouldn't trust myself to drive a pivot into a wedge incase it jams and gets damaged/snaps trying to get it free. More a comment on my ability and incompetence than the quality or design of the tool 🤣
    • @clockboy The damage on the movement much worse. The images against the green background are my watch the other 2 are from the internet. The rotor has erased the perlage. I am surprised how is this watch still running.
    • Hi All, I recently bought a few gauges on Ebay. One of those was my actual target, a roller jewel gauge. Pictured below was one of the other gauges I received. From what I gather, this one is for measuring pivots. No sure if I'm right here. A confirmation of my assumption would be great. The gauge also has an abbreviation of "DEN". I have looked around and don't find this relative to watchmaking. Any clue to what this abbreviation means? Thanks, Don
    • Hello and welcome to the forum. Te attached file my help you repair a few. TZIllustratedGlossary.pdf
