Hi all,
Any suggestions on how to remove damaged screw heads on a wheel bridge?  They must have put super glue because I damaged the heads on all 3.  Thanks.
Alum disloves steel or if you ready to invest 70 bucks on a dedicated brgeon tool, otherwise it is down to applying penetrating oit and see what you can do with needles and sharp poiinted screwdrivrs, sometimes heat-quench helps.
Hi Jeryl        It all depends on the manner of how they are stuck,   unlikley they have been glued but may be have had thread lock applied, therefor Nucejoe's method of heating with a soldering iron tip might break the hold, also applies if its rust/corrosion.  But if its the fact that they have been cross threaded that's a different matter and they may require cutting out with a specific tool or a drill.
