Omega 1337 Movement
rogart63
Welcome through to the other side :) . Unfortuanly something snapped in the movement .Think it's the sliding pinion . Have to put it aside for some time . I now that Cousinsuk have the sliding pinion . Not sure it's worth to spend the money if the other parts don't work . This is the last pictures just before i tried to turn the crown to much . All the gears work up until when it should turn the date ring . Thats  when it snapped or crashed .
Edited by rogart63
At least i am learning something . I am not giving up . It just takes a little longer . BTW i found the problem that  made the sliding pinion brake . I had turned the crown wheel upside down  . When i tighten the screw it was impossible to move . But i think the pinion was worn already . Will put the rest of the movement  together to see if it is working . Maybe then i can buy a new pinion for £20 . Maybe even find a working movement and put the electronics in my serviced movement instead .
Edited by rogart63
WOW!
I never thought it would clean up so good mate.  Especially the battery area :o
And it's an excellent movement to practice on too.  Not to easy, and not too hard ... juuust right!
Really looking forward to seeing the end result of your hard work.  Keep it up!
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
