Help Me! Beginner Here
To all whom may be able to help!
I am a beginner watch repairer, but I have hit a snag straight away! I am having real difficulty getting into screw watch backs basically.
I have the right tools, I'm not sure of the name so I will call it...a three prong watch back removal wrench...sounds right to me. I'm lining the sucker up, using the best fitting pegs and applying the best pressure plus anti clockwise movement I can but getting absolutely no where.
It literally just does not want to budge, I've scratched the back already :( I do have a watch back removal ball on the way but essentially I was wondering if I was missing some essential piece of advice in regards to using the aforementioned wrench.
Any advice would be much, much appreciated!
Welcome to the forum George, from George. :)
As you have found, some screw backs can be so tight you would think they had been welded on. The tool that you are using is fine for the majority of backs, but occasionally you come across one like yours. Before I purchased a heavy duty bench mounted back opener, I would take the strap off and hold the watch very carefully in a vice fitted with soft faced jaws. The lugs of the watch would dig into the soft jaw and give a really tight grip. I would then be able to press down really hard on the tool while unscrewing the back.
Read this thread:-
http://www.watchrepairtalk.com/topic/700-stuckwatch-back/?hl=glue
Edited by Geo
Hi George and thank you for getting back to me!
Yes I swear to the Almighty it feels like the back has been welded on! I do have a watch vice coming and I am going to purchase a table vice soon so hopefully I can use these to good effect! I was just wondering if there was anything I was missing thats all, such as offering it a sacrifice!
What sort of experience do you (and others) have with using the removal balls? Are they actually any good?
Oh I like my stick ball. I use it quite often to spin a back off or on when it has been slackened. I have also opened a couple of odd screw backs with it occasionally.
Just one point to chip in, from one beginner to another. I had one watch that had a back like that, and no matter what I tried, I could NOT unscrew it.
Then I looked at it VERY closely - and it turned out to be a snap-back, that just happened to have the little divots that LOOKED like a screw back. I even have one of those "crab claw" back removers, as well as the Jaxa-style remover that you describe. The crab claw only grips into two opposite divots, but can exert better leverage. I stopped short of (1) scratching the watch back, and (2) adding to my already more than adequate vocabulary!
It was only after I twigged that it was, in fact, a snap back, after spotting the tiniest of little "ledges" on it, that I used a Bergeon knife back opener to pry it open and it popped off as easy as pie...!
Luckily, nobody was around, but I still felt like an idiot!
Pete, Brisbane
Welcome George, As Dr Rock says make sure it is actually a screw back. I came across one a few years ago it was a fake Raymond Weil watch. It was just a snap back made to look like a better quality watch.
There is lots of new & experienced guys on this forum so don,t be slow in coming forwards even with the most basic of questions.
It,s a never ending but enjoyable learning curve.
Edited by clockboy
I should perhaps have mentioned that the watch I was referring to with the back that looked like a screw back but was actually a snap back was indeed a fake. It was a fake Chopard. It actually looked terrific. But most definitely a fake.
Pete, Brisbane
Hi George
I agree with Clockboy and Dr Rock
I have also come across these imitation casebacks ( I think Ruhla watches have them) just check the edge for a pry hole. There are also casebacks you will come across that will require a certain type of hexagonal wrench..
Darren
The ball is an excellent tool.
One thing you might consider that worked for me is to use two cleats instead of three one directly opposite from the other. Definitely use a holder or you'll scratch up the case when the tool slips; worse yet you can cut your hand.
Always use the right tool for the job, if you don't have one, order it and be patient until it arrives.
    • So all that glitters is not gold when it comes to buying from ebay ( in fact very very rarely) i bought this as554 a few months ago. It was it's dial that attracted me to the joblot, which turned out to be printed on a postcard, that was the first red flag. During disassembly many faults were discovered as listed above,  but i was prepared to soldier on and see what i could achieve. I managed to make a setting lever for it which was a great learning experience and also correctly shape and de rust the hairspring.  Turning my attention to the balance assembly i have hit a road block. The staff broke when removing the roller but that wasn't so much of an issue as it was quite deformed anyway.  I also had several AS554 staffs that I could replace it with, problem is they dont measure up the same. I thought i had identified the movement correctly but what i think has happened is some heavy modification has taken place to make an incorrect staff fit. A nos staff is a slack fit on the balance wheel, the roller and the collet. The balance wheel has also been filed to within an inch of its life. I'm starting to doubt my identification of the movement either that or someone has converted the movement into a pure nugget of trash. Bit disappointed as i managed to get the train to spin lovely and put a good few hours into the setting lever. A balance complete might be the only option if one is available but you know when you are just wasting money. My thoughts are to make and modify something else to fit and work if that is possible, any ideas anyone ?
    • My second iteration. Cleaning to be underneath the towel rails. That makes sense. Moved the fridge and the maching/printing table around to the right. Changed the lathe to be used over the end of the bench. Not much room in front of the 3D printer, but you don't have to stand there while it is doing its thing. I may swap the fridge and the machining/printing bench yet. Not sure. And the 'doing' area. The power that was brought in for tha spa was 30A I think, so there will be more power than I need. I will have to check how level the benches are as well as find a spot for the movement testing rig to go. The tiles do have a fall toward the drain so I will have to work something out to be able to level the rig easily no matter where I put it. I'm also going to cut some slots in the bottom for pendulum clearance and some squares in the top section to be able to better see the movement. I'm getting more excited now.
    • Thanks Rich and scott for that information,  so much more to learn.
    • Ah i didn't notice that but it was past one i  the morning when read it  The keyless works used for identification are hidden under the watchmakers side. You would have to disassemble it, you dont need to worry so much about that, doubtful it is a Remontoire as i suggested earlier this morning 🤦‍♂️ but you never know 😁
