Should I lubricate the post that the roller jewel goes on? What about the eccentric cam on the date driving wheel that the roller rides on? Marks videos do not show lubrication in these areas. What's the prescribed procedure?
Thanks. I'm also seeing a no lubrication symbol for the corrector wheel. I see in mark's video that he lubricated the elongated hole for this wheel. Does lubrication go there? Or is there absolutely no lubrication for this component. Another question regarding reversing wheels. On a diagram I see in another thread it also shows no lubrication to be applied on the teeth or pawls whereas in mark's video he applies lubrication on the teeth. Is his procedure incorrect? What is the purpose of requiring epilame on these if no lube is applied here? Also the diagram does not show lubricating the date jumper on the part that indexes the date wheel. Should this area be lubricated like many other manufacturers do? Or is this not necessary?
