I could have used one like this the other day when I was trying to insert a barrel arbor.
There's no way I'm paying $40 for one though. I got to thinking I could make one myself with some brass bar and my drill press. Is brass to soft for this purpose? Also, can anyone with a Bergeon 1902 give me the approximate size?
Thanks,
Don
Brass would almost certainly be a bit soft if you were going to actually use it for rivetting. However, for tasks such as installing barrel arbors I don't think it would be a problem.
I have a number of these rivetting stakes (including one that somebody made out of brass) that I have picked up in job lots of stuff over the years and they are very useful to have around. I have one which on the face of it looks like the one in your pic but I don't know if mine is a Bergeon 1902 or not. It's certainly the same arrangement and number of holes. Dimensions are 50.2mm x 14.9mm for the top surface and 5.9mm thick. It has a cross section like a fat "T" with the vertical being 10.5mm thick and the horizontal being 1.8mm thick. The biggest hole is approx 2.5mm diameter, and the smallest is approx 0.25mm Diameter.
Hope this helps.
The non-bergeon ones are much cheaper and do the job just fine. Why go to all the effort when they are so cheap.
E.G. http://www.ebay.com/itm/small-rivetting-stake-block-/281074274283?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item4171550feb
Or: http://www.ebay.co.uk/itm/NEW-Watch-Tools-Rivetting-Stakes-Set-of-Three-Pcs-/361188193705?pt=LH_DefaultDomain_0&hash=item54187e75a9
Mine is not Bergeon and I have had it since my apprentice days :)
Thanks for the links, Mark. I ordered from the first one for less than the blank metal would have cost me. I'll miss making something myself, but I can't justify paying more just for that.
Is there any difference in design/function between a riveting stake and a bench block of this style (apart from the number of holes)?
Thanks in advance!
Roger
Edited by 64americandeluxe
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
