I opened up this Timex Expedition T42351 to remove a tiny loose metal sliver from the dial. This watch actually has 2 stems to remove. One of those is a monster. I swear I felt like I was pulling a parasitic worm from a wood boring beetle as I slowly worked the main stem out of the movement.
But it came out, I dropped the movement out of the case, removed the metal sliver - which looks like some kind of tiny flat spring - cleaned out the dust particles and proceeded to re-assemble the watch.
Everything went fine until I attempted to slide the main stem back in; it went about halfway and then stopped. With some very careful manipulation I was able to ease it in a little more, but then it refused to go any further.
I did notice there's a very loose 2-pronged spring near the entry hole and showed that to a watchmaker friend yesterday who told me that it's broken. He wouldn't touch it and advised me to just go get another watch. But I'm pretty sure there must be a way to get the stem back into the movement and regain the functionality the watch had before I opened it up.
Here are pics of the watch, the loose sliver, and the stem with the movement. If anymore is familiar with anything like this, I'd love to hear your opinion. Thanks!
Fixed it.
After tweaking and staring at the watch for around half an hour I finally discovered that the "spring with wings" assembly (visible in the 3rd photo just above the stem's entry hole) needs to be gently pulled upward until it friction-locks in place. You can then carefully insert the stem the rest of the way into the movement. Once the stem is in place, push gently downward on the spring until its underpinnings click around the stem shaft.
Hi, watchweasol - Tnx for the service sheet. I just took more pics, these should be clearer. Showing the spring assembly in the open and closed positions.
  • Similar Content
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
