Hi all,
Have just obtained a nice Swiss Emperor watch that is in need of a service and has a problem with date wheel not turning( I thought that the Date Jumper just needed re-engaging) the movement is ST 96-4.Upon dismantling the movement I found that the problem is that the Date Jumper Spring is missing which is not a problem as I can get them on my account at Cousins but my question is does anyone know which way it goes in in order to engage the Date Jumper, does the longer section go to the back or the front...
If anyone has any ideas and can help that would be great
Best Wishes and a Happy New Year to all
Darren
Many Thanks Blacklab
I did have a look at this post but it does not give a real clear indication of the position of the spring
But many thanks for your help it is much appreciated
Best Wishes
Darren
Hi Blacklab,
My sincere thanks to you for replying when you could have been out bringing in the New Year it is greatly appreciated. This movement is indeed similar but mine looks to be an actual wire spring but maybe i could get the replacement in the same form, still it gives me some idea on which way to go with it, the movement has all been stripped down,cleaned and put back together and is working great ( except for the date portion which I will attempt when I get the spring)
Many Thanks for all your help Blacklab, much appreciated
Best Wishes
Darren
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
