Timex 24 setting lever
Haboy
Setting lever screw broke on my Timex 24 movement. I have another working 24 but in need to install the setting lever and new screw which seems somewhat impossible. Is there an easy way to get the lever and screw inserted into the hole?
Hold the setting leaver exactly in place with rodic (or similar), position the screw with tweezers, and screw in place.
... or..
Position the lever with rodico, position the screw with rodico, screw in place.
It is fiddly. I presume you removed any remaining parts of the broken screw.
One other thing that occurs to me.
Fit the setting lever (443) and the screw (5443) *BEFORE* you fit the stem and crown.
Once you have it fitted, screw the screw right down, then back off by about 2 1/2 turns, then fit the stem under the tab that operates the lever and position it correctly. With the crown/stem in position, screw the screw back down till finger tight, and prove the lever/crown/stem is operating correctly, then tighten the screw completely.
Attempting to fit the setting lever, crown/stem and screw all at the same time is a much more difficult (and unnecessary) task.
Edited by AndyHull
most times the broken screw will be accessbile from the dial side of the movement.  I use a pair of fine tipped diaginal cutters to grasp the screw and slowly turn it out of the hole.
TIP -  Apply some watch grease to the bottom of the set lever to hold it in place.   Line up the holes and with tweezers, drop the set screw into place.  The turn the screw about 2.5 turns.
Thank you AndyHull and JerseyMo for responding with really helpful instructions!  You guys rock!  i have to get some rodic to help hold these two little mini-monsters in place. I was trying to use a small bit of sticky-tack but it didn't hold well enough.  I would get the screw into position but it would fall over when the screwdriver touched the screw.
For the 24 movement that still has the broken screw end in it, I will try to get that out after I get the lever and screw installed in my working 24.
And yes, I will install the crown/stem AFTER I have the lever and screw in place on the plate. Again, thanks for your help- i really appreciate it!!!  Will let you know when I get things back together.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
