Seiko Snke63
Don
Nice watch Don! I've got so many Seikos (some of them restored as part of my learning experience) that I can build one in my mind in no time flat. I love those movements. They are easy to service and to basically do anything, at a nice price, good precision and good looks: what else can we ask for?! And the watches are really something, like the one you have here. Under the simple and luxury kind of appearance ticks a very rugged movement that will take a lot of punishment before quitting!
By the way, when servicing the 7S26/7S36, the only thing I'm winging is matching the day and date rings so they line up perfectly with their window in the dial. Is there an easy way to do this? I've noticed some of the "gears" on the day disc show through holes in the disc as if indicating something but I can't figure out how they need to be aligned to match the date disc. I don't know If I'm being clear in my question. In any case, if you -- or any other member -- have done this operation I'm all ears and willing to learn from everyone's experiences.
Cheers,
Bob
Thanks Bob. It's a goal of mine to service my Seiko Fives. I'm a big fan of them. Inexpensive, durable, good looking. What's not to like?
I wish I could answer your question. Hopefully someone else can.
Hallo Will's Snk615K1. Nice watch!
I'm with Bob in that I find the day and date alignment pretty hit and miss. I've heard that you can correct this by tweaking the 'jumper', ie bending the arm will achieve some measure of 'fine tuning'. Apart from the alignment... on some watches it doesn't change with a snap but will then to get hung up and needs a shake of the wrist to get it right.
Anil
Cheers,
Bob
I've found this too Bob.  Most frustrating indeed, and I haven't found a trick to aligning them without refitting the Dial and running it through it's pacers :huh:  If any of your cleaver dickies knows the secret, please do tell :)
Also, I'll throw my Brass Farthing into the comments on the Seiko mechanical movements.  I love'em!  And I said as much in my 7S26A walkthrough.  They are a really good movement for beginner to gain confidence on.  Everything is laid out beautifully, and it's a very logical process to service one.  And for those who think Seiko's aren't up there with the high grade watches, you need to look at the "Grand Seiko" Range ... simply stunning!!  And their "Spring Drive" Technology is world class.
It's such a shame their name got so badly tarnish in the 70s and 80s cheap quartz furor, and the Swiss have NEVER let the public forget it.
    • I can't answer your question right now but I have these in my Seitz jewelling tool and my impression is that they are made for large, pocket watch size, cannon pinions. I prefer the Cannon Pinion Tightening Tool, Bergeon 4733. Perhaps the pusher and stump could be dressed to work better with small and normal cannon pinions!?
    • Hi there thanks again for your help... I don't think it's that staff. The broken staff measures (with a tolerance for my crude measuring) A=402(but has a pivot missing) B=173 J=132 G=56 K=93 The A length seems too small....but the best fit has the right keyless works.....I wonder if the keyless works is common to another calibre? Just for info the balance cock is original as the machining pattern on the movement matches...so I'm assuming it isn't a '**BLEEP**' movement. This is why it's stumped me! 😁
    • Due to the nature of the steel intended for its use it will have some hardness, but not that hard. I've chipped the sharp cutting edges of loads of these .  Your drill bit is probably slipping on the shiny chrome plated surface, it wont bite until it gets through that. Try a center punch or otherwise cobalt or carbide bits.
    • A recent lathe purchase ( Pultra P type ) I have a thing about Pultra lathes turned up something I have no idea what they are for. they don’t look shop made but could be . Dell
    • I thought about if Ross could carefully drip alum into the hole to dissolve the screw so the outside of the arbor is unaffected.  It risks the arbor thread but with the arbor being hard and the screw is soft maybe the screw would dissolve before that happens.  Not sure if Alum reacts to the carbon content in which case the arbor has more than the screw. Re-threading the arbor would be a problem. Might be worth an experiment,  i have a few hundred random arbors, shame there isn't an arbor database like there is for staffs 🤔
