Had a bit of practice fitting a shock spring which was fun, and ended up making a little tool to fit it back into the movement.
Anyone know what the spring is called, movement is a Seiko 7S26.
Many thanks from Jon
  • Confused 1
5 hours ago, WatchMaker said:
That looks useful!
What the spring is called? It's a Diashock i.e. Seiko's shock protection system.
Thank you.
I can only seem to find pictures of the flower type design and not the one pictured above so was a little perplexed.
1 hour ago, rogart63 said:
Only seen them on newer 7 series movements and some newer Seiko movement. They are a pain in the ....  to put back.
Agreed.
I played around for a couple of hours, then left it till the next day and made my little tool which did the trick.:woohoo-jumping-smiley-emoticon:
