Greetings,
I have just obtained an older 7750 chronograph that's in great shape and running well. It was +8s/d after a week on the wrist, and I checked it on the timegrapher. The first thing I noticed was that the beat error was around 0.5ms - 0.8ms in various directions. Dial down was around +10, and crown up was +6. I took a lot of measurements before changing anything on the hairspring.
I thought fixing the beat error was the first thing to do - so I got it down to under 0.2 and noticed something frightening: It would now gain 30+s/d in one direction, and lose 10s/d in another. Wild positional in-accuracy! I then moved it back to a 0.5 to 0.8 and regulated the movement down to -2 Dial Down / +2 Crown Up. After a few MORE days on the wrist it seems to be stable and keeping great time.
Why is this happening?!
Thanks!
- Kris
No idea. Maybe the hairspring is touching something if you lower the beat error?  But i wouldn't sweat to much if the beat error is 0,5. As long as the watch is accurate.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
