i need to replace a seiko 7S26 automatic movement...the watch is day/date....the movement shipped to me is a date only...seiko told me that this model number is available only in date and they make none with a day wheel....all well and good but my movement is stamped 7S26 and it has a day wheel...is this a complication added at time of installation with extra parts purchased...driving wheel and day wheel???...thanks....
Hi rattandson,
what is the new movement caliper (stamped on the rotor hopefully)?
I believe this movement is discontinued for sale in itself (7S26), although it can be had still in new production Seikos. Alternatively the discontinued 7S36 is completely interchangeable if you find a working one. Also a rebuilt 7S26 can be had from here: http://www.10watches.com/apps/webstore/products/category/347351?page=1.
I believe the 6R15 is the modern version of the above movements so it can be replaced -- hopefully directly -- but the price may be higher. It is a much improved movement that I think allows for manual winding and hacking.
If you have your old movement day/date in good working condition and cosmetics, you might be able to "transfer" those complications or the part(s) that you need to the new movement...and then again you might not depending of the answer to the original question above.
The original plastic gears for the 7S26 are available from cousinsUK (only, to my knowledge) those are particularly touchy and easily broken if not properly assembled. Also the retaining day c-clip tends to jump into nowhere if not treated carefully, it has an underside "dent" at 6, when the opening is at 3, for a small screwdriver to be inserted (removal procedure).
In any case, here is a helpful link that might be redundant in your case: http://www.clockmaker.com.au/diy_seiko_7s26/
Cheers
Bob
Funny thing Bob, I was looking into this the other evening. There is also the NH35 (date), NH36 (day/date) & NE15 (not available until April 2015 from Cousins). All appear to be the same dimensions as the 6R15, however the 7S26 is 4.9mm high the others range from 5.25 to 5.32 high which may cause the second hand to foul the underside of the crystal.
That is correct Blacklab,
I've never done the swap so I may be here getting into unknown waters, as I usually restore these movements (again never swap). Still, I believe I read about this issue and the fix was to swap the cannon pinion and/or just the hour wheel on the 6R15, now don't quote me on this one since it was a discussion on another forum. I'm hopping another member that has done the conversion will jump in and give his 2 cents.
From other websites I put together what I found related to this topic:
"More interweb digging... It appears that the NH35 shares a few parts with the NH25, which I understand shares some parts with the 7s2X series... it's getting interesting. It appears that both movements should share the same hour wheel and many of the keyless works bits as well. It really might be as simple as installing the day wheel and clip on the movement...."
"The good news first! You can put the 7s26 day wheel into the NH35A movement, essentially making it an NH36! You have to swap the hour wheel and the quickset cog and that's it!! It all works perfectly, everything clicks like it should, it sets perfectly! I thought I was about to have myself a hacking SKX009. Then, after it was all reassembled (no small feat in my current condition), I was excited to have my hacking SKX. As I went to insert the SKX stem (an integral unit with the crown), it all went pear shaped! The SKX stem is too large to fully insert into the SII movement. The interference is right on the main plate of the movement. A problem that can not be solved without either machining the stem or the movement... icon_e_sad.gif Needless to say, I am disappointed. Now I wonder if it's possible to take the hacking bits from the SII and put them into the 7s26 icon_neutral.gif That will have to wait for another day. I don't even think I can do the swap back right now... Having the leg down that long was not the best..."
"Pop the stem in to your dremel tool, break out a diamond file, and gently turn the stem down to fit... I had to do that operation to get one of my Rolex shoulderless spring bars to fit in the holes I drilled in ExploMaster. Worked well enough, but I had extra spring bars - how many stems do you have? Are they easy to get?"
"I haven't checked on the availability of stems. The SKX stems/crowns can easily be had from Jules Borel. 10watches used to have some aftermarket crowns, that I think took a threaded stem, but I haven't seen them on the site for a while. My only rub with turning down the stem, is that then the watch the 7s26 goes into has a stem that doesn't fit right. Stems are so small and made of such brittle material, I think it's really important to have them fitting just right if you want them to last."
And so, there we have it, it could be done!
Hope it helps,
Bob
Same thing here Bob, I always try to repair rather than replace, however it does open up the possibility of buying a stripped out case & putting something reliable in it. Funnily, the same subject is being discussed on SCWF at the moment as well.
Excellent, do you have a link Blacklab, I'd love to follow up on this! I'm mainly working on Seikos nowadays and will like to "upgrade" some! Thanks in advance.
Bob
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
    • At the moment I have neither EDTA solution nor Evaporust, so I tried with a citric acid solution. This gave satisfying results for most of the parts, except for the ones that are really heavily corroded. I will see whether I can acquire one EDTA or Evaporust and try that next.
    • This guy (Minimachining) has a playlist of him setting up and using various attachments on his Sherline lathe.   I know nothing about CNC machines but had a question about making screws. Watchguy.uk has a section on his website where it allows you to enter parameters for screws and wheels and then 'generate code'. Is it as simple as that sounds, can you 'tell' the CNC machine to cut you a screw (or stem) by giving it the code for a particular screw or stem and it happily makes one for you?
