A Marvin For Christmas
WillFly
Well, I'm afraid that one Marvin just isn't enough! Spotted this last night and made an offer - a Marvin 510 from either late '40s or early '50s. The 510 movement isn't quite as beautifully finished as my 520, but the dial is lovely.
The seller of this advertised it as a 1940s watch (with the usual "military, WW2" shtick, which I ignored). Ranfft doesn't list a 510 - just the later 520, which appeared around 1955. So it could be a 1940s watch. Incabloc was invented in 1934, but I don't know when it started to appear as more or less standard in Swiss movements - it's certainly not in this 510.
So, on balance, it's possible the watch is 1940s - and the balance shock is decidedly a first for me!
    • Date (day) CAN be moved without issues from the crown (position 1) but it CAN NOT be moved by rotating the crown (position 2), nor does it move in a normal 24hr. cycle. Clock functions otherwise withiut issues. Brand new Renata. Thanks, V.
    • Visually pocket watches suit some people. Having bigger parts to work with makes things a little easier to understand, the con to this is older timepieces that have been messed around with. Teachers recommend starting with something new and in good working order, this way if it doesn't run after you have serviced it then you are only looking for a fault that you created. That didn't suit me though because I'm quite mad with a little crazy mixed in 🤪
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
