Tool Identification and Use
I was in London recently and took the chance to visit the Clockmakers Museum which is now hosted at the Science Museum. It’s free and well worth a visit if you are in that neck of the woods. One of the exhibits was this screw made by Waltham. The blurb says you can fit 47,000 of them in a thimble 😵💫 I assume it was used in a watch and they didn’t just make it because they could. It made me wonder though, how on earth anyone could work on something that small. You can “see” it in the centre of the box in the picture; although you can’t really tell what it is. For all I know they cut a grain of sand in a half and put that in the box!
By Embezelled · Posted
Hi all, I'm about to take my first steps into watch repair as a hobby, and looking into buying a basic and inexpensive stereo optical microscope from AliExpress. My main purpose is simply something I can use in addition to eye and head loupes, or in place of them, during disassembly and reassembly work. So I assume that means something that has only modest magnification at the low end or uses a Barlow lens to bring it down. And perhaps with a tiltable head. I really don't have an interest in combining it with camera work, I simply want it for viewing the movement at appropriate magnifications as I check things or use tools on the movement. Without asking for specific model recommendations, can anyone point me to the kind of model shown on the Ali website that might suit my purpose? I've been reading two of the threads about microscopes, very informative, but it's a lot to digest for the uninitiated. -
I can't even see the 3.55 you've shown when I search Cousins for the 2892-A2?
That's another interesting solution. Thanks for that. Aren't the Elgin staffs specifically designed to be a friction fit rather than riveted?
By nickelsilver · Posted
The pushing out method in modern times comes from Rolex, and they have specifically made staffs to accommodate it. I believe Elgin did something similar in the past. If you don't have a lathe, then a Platax or something like the K&D tool that holds the balance arms firmly down is the best. Still a risk of opening the hole. If you have a monometallic balance (no steel) you can soak in a saturated solution if aluminum to dissolve the staff. This won't harm the balance, and is preferable to punching out.
