Ingersoll Ltd Triumph Pocket Watch
surfluds
I have been given an Ingersoll pocket watch that I am going to see if I can get cleaned and looking good. The biggest problem is that it has no crystal. So I was wondering how to get hold of these. Is it a case of finding a spare repair on Ebay?
Also the movement is stamped with 552M, does this mean 1955 Feb.
Thank in advance
Mike
The crystals on watches inevitably get scratched or damaged so replacements are readily available in most sizes for most watches. Same deal if the one on your (pocket) watch is missing ... you just need to buy a new one.
For instance: https://www.ebay.co.uk/itm/1-BRAND-NEW-41-5-ACRYLIC-POCKET-WATCH-CRYSTAL-TO-FIT-SMITHS-INGERSOLL-SERVICES-9/163484960530 may hit the mark. Obviously measure the diameter of the recessed area on your watch that will hold the crystal to double check the diameter before you buy; if this link isn't correct for you then search for a pocket watch crystal of the correct diameter.
As to the 552M this is almost certainly just a model number. [Your logic is a good guess but this would imply there should be, say, a 551M for a January production but Ingersoll and 551M do not come up as a match in a web search].
    • if you're trying to keep track of conversations scattered all over the message board emails are an absolute must.   looking at the bell icon on the top of the page versus the emails today it looks like I got the correct amount of emails. So making some minor change based on the one of the images up above I started getting notifications again. But at times I still have a suspicion that something isn't quite right. I have some feeling that the message board may delay sending emails until something so seems to be a long delay between when you get your emails just a weird feeling things aren't quite right oh  and then even though I do seem to be getting emails I no longer get notifications of personal messages I don't find that out until I arrived at the message board where I'm pretty sure I used to get notifications of those two. So something is definitely changed on the message board. then for everyone not getting emails you do want to check your spam folder. I have found that sometimes were open up an email the system I use warns me that it thinks the email is evil and bad and I have no idea why he thinks some of the emails are and some are not. But this is actually the program I use not the email system which also has a mind of its own as to what it considers spam so you should always check your spam folder.
    • 10.46 according to Google. What do I do with it once I have the measurement in lignes?
    • If you Google "site:watchrepairtalk.com Unruh" it should answer your question. https://www.google.com/search?q=site%3Awatchrepairtalk.com+Unruh&sca_esv=cd1cd8ba04cfc6b9&rlz=1C1BYYL_svSE993SE993&sxsrf=ACQVn08-tJuTdvkJ1CZdy5PcUR7BB6zDaQ%3A1714681373604&ei=HfYzZtTBJPf8wPAPnsySiA0&ved=0ahUKEwiUxLTx5e-FAxV3PhAIHR6mBNEQ4dUDCBA&uact=5&oq=site%3Awatchrepairtalk.com+Unruh&gs_lp=Egxnd3Mtd2l6LXNlcnAiHnNpdGU6d2F0Y2hyZXBhaXJ0YWxrLmNvbSBVbnJ1aEjfCVAAWABwAXgAkAEAmAEjoAEjqgEBMbgBA8gBAJgCAKACAJgDAIgGAZIHAKAHLQ&sclient=gws-wiz-serp
    • If you loosen the case back does that make any difference?
