What do you all thinkg about this Tudor Heritage Ranger? Ever since I read about it on Hodinkee, I've been in love with it.
Tudor are nice, mid-range watches. It does annoy me when, on eBay, you constantly see them up for auction as "Rolex Tudor" - trying to beef up the provenance. As Clockboy says, not a Rolex movement in sight - straightforward ETA - but perfectly sound for all that.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
