When cleaning a movement in my ultrasonic a jewel in one of the bridges came out and needs to be put in again using my not so often used Seitz set.1950b9f19b3baebe193f575ffb1dd32b.jpg
When inspecting the hole I note a couple of tiny (maybe 1/4 of the hole diameter)circles at the edge that I started to suspect may come from a previous trial to tighten the hole just slightly with a punch around the hole edge.
I have attached a photo that I hope shows what I think can be the punch marks.
Would this be an ok method to tighten the hole and something I can repeat as I guess the jewel will not sit very safely when pressed in again?
When viewed from the top side, I note that the hole is lined with a brass ring that doesn’t go all the way through. Why were these brass linings used? Softer material?
Can you post a pic of the other side? Sometimes on normal grade pieces they were retouched around the jewel hole after plating to show the brass and give the impression that the jewels were set in chatons.
Hard to tell if a previous attempt was made to close the hole. You can try a domed (convex) punch to close it a little. Try a punch where the round face is about 50% bigger than the hole. I like to do a little from both sides.
Hi,
Photos are attached and I think you are probably correct. Looking closer, what I thought was a boundary between the chaton and the bridge inside the hole, probably is just the edge between plating and brass.
Hopefully you can judge from the photos?
18 hours ago, bsoderling said:
Hi,
Yes, those are "fake chatons". The bridge itself is made to look like it's 3 separate cocks. What's interesting is some makers went through such efforts to make the product look more high-end, while it was fairly certain the only person to ever see the movement would be a watchmaker.
I think the "fake chatons" and general attempts to show off generally dates to earlier in the century when customers were more likely to see the watch movement in the shops, especially if it was a shop-built watch made to order. It was common back then to choose a particular movement and have it mounted in a standard caselike a Dennison model, for example.
One other thing you sometimes see is an enlarged cap jewel which is visible when looking at the balance cock, yet the cap jewel fitted to the plate is much smaller. Purely cosmetics to "wow" the customer.
Then in the 1970's we have the fight for maximum jewel count, with superfluous cap jewels everywhere.
One thing is sure; human behavior never seize to amaze...
A quick update on my progress.
I decided to fit the jewel without trying to reduce the hole first, just to see how loose it would be. When pushing the stone in, after a bit it suddenly shatters in small pieces. I suspect there was an edge or burr or something that pinched too hard at some local point.
Almost caved in at that point but decided to have a look around some other less fortunate movements in my drawers. And indeed, an old pin pallet movement I never got to run had a jewel with the same dimension and this time the pushing-in worked better and the jewel seem to sit safely.
Regarding the technique to reduce the hole with a domed punch, I suppose one has to be very light handed to not overly deform the edge of the hole too much?
As I see it, all the force from the punch will be focused on that tiny area where the dome meets the hole corner. I suppose what one wants is to have material deeper into the hole to expand and reduce the diameter, without creating burrs and deformations on the edge?
One thing to check (which you may have already done) is the hole size (which then corresponds to side-shake) when you selected the new jewel. You can simply take the relevant wheel and sit its pivot in the new jewel hole and observe the angle which the pivot is permitted to move from side to side. You can judge this by eye.
I think I did pretty much that. As you say, wiggling the jewel on the pivot is a decent way to ensure there is a reasonable side shake. Good to know it’s used by others.
    • I've found with Russian watches they don't stick to the Swiss numbering system. The problem with the mainspring is that as this is a dual barrel system they're very small compared to most automatics. If you look on Cousins the weakest 1.45mm high spring is 0.085mm which could be too powerful for this movement and is also designed for a 7.5mm barrel. If you then look at the GR Catalogue and work back from the GR3930X, this is the first auto with correct power rating. Although you'd probably have to go back further to this one to make sure it fits.
    • Hi all, I’m currently working on an ETA 2836-2 movement. I replaced the pallet fork with a new one (ETA2801710, sourced from CousinsUK). After full reassembly and lubrication, I’ve encountered a strange issue: The movement is fully wound and has power. When I fit the balance assembly, the movement does not tick at all—completely dead. When I remove the balance, the gear train suddenly releases and spins freely, indicating power was present. The pallet fork just “floats” without snapping side to side—almost as if it isn’t even there. No interaction with the escape wheel is visible at that point. However: Before fitting the balance, I checked the pallet fork manually — it was working as it should, clearly interacting with the escape wheel. I’ve inspected the pallet bridge jewel (where the pallet fork sits) and everything looks normal. No signs of misalignment or obstruction. I’ve rechecked everything I can think of and I’m completely out of ideas. Has anyone seen this behaviour before? Any suggestions would be greatly appreciated. Thanks in advance! TT
    • Thanks for the prompt response. I apologise for not stating the issue more clearly. The problem is that - what I now know I should have called - the centre wheel is not being turned by the pinion (which is driven by the barrel) with which it shares the arbour (1st photo above). The pinion & arbour are indeed reverse threaded but the arbour (the 'screw') is clearly damaged ('rounded' rather than 'sharp' threads) with swarf evident. When the pinion is screwed on there is only enough connection to prevent the pinion being lifted off but not enough to stop it turning on the arbour. Is a (reversible) repair (threadlocker?) possible in the short term while a replacement centre wheel assembly is sought so that the viability otherwise of the watch can be established?
    • Sorry this is a bit late but how did it go for you?   I'm working on a 561 with a similar issue. Cheers, Martin
    • I'm struggling to put it back so I'm going to watch a tutorial so may be a few hours.
