Just purchased this pivot polisher and was wondering if anyone has specific info on how to use it. I installed it on one of my lathes and trying to understand specifically the technique for finishing balance staff pivots: if that is possible.4ce3e13849e953c634572a8b81a63951.jpg80ec1e2b01575d82d24580cb49d1a325.jpg726b1c61c74723ba1e685701960d6813.jpg
Archie Perkins' book on lathes and Marvin Whitney's book on marine chronometers give quite detailed descriptions of the use of these tools, the Levin book has some good info too. They are what a regular machinist would call a grinding attachment. They can produce excellent results, but the preparation of the laps and setup of the tooling is very time consuming. If you're looking for an easy way to finish balance pivots you're better off getting your basic turning on point and finishing in a jacot tool. If you want to avoid the jacot then wig wag tools (Perkins and Levin go into detail on them) are a much faster solution.
Thanks. Just thought I would try this one out, plus, it's a tool:)
Sent from my GT-N5110 using Tapatalk
Is wig wag tools a book and how do I get it?
A wig wag is a tool for polishing pivots or other arbor diameters, it's used from under the work, and one side is supported by the tailstock and the other is on the work. Fried refers to them briefly in his Watch Repairer's Manual but he calls them "polishing shovels". The image is from the Levin book Practical Benchwork for Horologists. The support part in the tailstock is eccentric and by changing its position you can vary the angle of the part of the wig wag in contact with the work. Some tailstock supports have a roller, some are very simple and solid. The wig way itself can be dressed to make straight shouldered or conical pivots, and a basic rounded edge can produce a number of different conical shapes by angling the tool in use.
Ah, thanks. I have seen write up on these in the past and ignored them
So I set up the pivot polisher and have a question. The cord that came with it, when tied together in a knot, the knot will not go around the lower pulley wheel. Is there a better way of knotting the cord so it does not get jammed when traversing the lower pulley?492c375fa59d728ee942c848c8395ab3.jpg
That looks like a twisted leather cord, it should have a sort of staple, not a knot.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
