Hello Mates!   And a happy before Xmas !!
Got in a Certina Certronic 29-151 movement, that had not been operative for many many years.
I will try to replace the battery first, after checking for everything look OK.
But must this have a reset after battery change?  Or something that I must do before replacing the battery?
HO... HO...     Xmas regards
From Armand
Happy X-mas and all that good stuff!
 I looked up your movement and its the same as Omega 1250 aka ESA 9162.
Quote
that had not been operative for many years
This detail here tells me  the movement needs a service. These are difficult to work on because of the index wheel which requires a microscope to align with the pawl jewels. I tried overhauling mine once and it REALLY require a microscope and specific knowledge otherwise you'll mess it up....:turkey:
OK, so having said that, if you try a new battery, put the watch up to your ear, and if you hear a high frequency humming, then the coils are good. Take the battery out and start looking for a tuning fork repairer. You'll still need a goo cleaning and lubrication, but at least you won't have to buy new coils.
J
